HORN BUTTON ISSUES - Ford Truck Enthusiasts Forums
HORN BUTTON ISSUES
Old 01-28-2014, 01:37 PM
oldmerc's Avatar
oldmerc oldmerc is offline
oldmerc
oldmerc is a name known to alloldmerc is a name known to alloldmerc is a name known to alloldmerc is a name known to alloldmerc is a name known to alloldmerc is a name known to all
Question HORN BUTTON ISSUES
Okay I am sure this is a dumb one and mindlesly simple but I can't get the horn button to engage on the 3 prong spring thing .
Any words of wisdom ?
Old 01-28-2014, 02:05 PM
jimcar-9 jimcar-9 is offline
jimcar-9 has a good reputation on FTE.jimcar-9 has a good reputation on FTE.jimcar-9 has a good reputation on FTE.
maybe a dumb answere but puch and turn???
or you maybe already tried that
Old 01-28-2014, 02:06 PM
Osubuki's Avatar
Osubuki Osubuki is offline
Osubuki is starting off with a positive reputation.
Horn button issues
I fought with mine after installing a new wire. No matter how hard I pushed down on it and tried to twist the horn button on I couldn't get it to engage on the 3 tabs. I finally had to bend the 3 tabs up ever so slightly to get it to seat.
Old 01-28-2014, 05:10 PM
Jolly Roger Joe's Avatar
Jolly Roger Joe Jolly Roger Joe is offline
Just another Joe
Jolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud of
I got a new (probably Chinese) horn button for Christmas 2 years ago.
I had to actually shave part of the button off to get it to turn inside the wheel.
Old 01-29-2014, 08:03 AM
oldmerc's Avatar
oldmerc
I have sworn to avoid violance but I will give it a try .
Old 01-29-2014, 08:07 AM
oldmerc's Avatar
oldmerc
I have been contemplating this technique as well
93 F150 horn problems stang9090 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 0 09-24-2015 04:00 PM
1960 F100 HORN QUESTION NMcGee1960 1957 - 1960 F100 & Larger F-Series Trucks 15 08-25-2014 06:20 PM
horn button spring centralNH 1967 - 1972 F-100 & Larger F-Series Trucks 2 03-17-2014 08:51 PM
Horn Buttons Horn Rings ??? gangstakr 1961 - 1966 F-100 & Larger F-Series Trucks 12 02-03-2014 01:29 PM
Horn Buttons Horn Rings ??? gangstakr 1967 - 1972 F-100 & Larger F-Series Trucks 4 02-01-2014 09:19 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
