2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
08 Expy EL Limited washer pump location
Old 01-27-2014, 03:39 PM
brfan's Avatar
brfan
brfan is offline
Hello all... Need to replace my windshield washer pump and I was wondering if someone could tell me where it is located?
Thanks!
Old 01-27-2014, 05:06 PM
RI-Matt's Avatar
RI-Matt
RI-Matt is offline
Mounted to the washer reservoir.
CAUTION: When servicing the windshield washer pump be careful not to damage the windshield washer pump seal.
CAUTION: Do not operate the windshield washer pump before filling the windshield washer reservoir. Failure to do so may result in premature pump failure.
1.Remove the RH headlamp assembly.
2.Position aside the shield as necessary to gain access to the washer pump.
3.Disconnect the windshield washer reservoir hoses.
4.Disconnect the windshield washer pump electrical connector.
5.Remove the windshield washer pump.
6.To install, reverse the removal procedure.
Matt
Old 07-21-2018, 11:21 PM
czama35's Avatar
czama35
czama35 is offline
Thanks for the info, I think I have the same problem and likely need a new pump but want to make sure.
I disconnected the hoses and made sure they were clear / check / all clear
Before I go directly replacing the pump motor is there a fuse that I should check ?
I looked at the list of fuses in the owners manual and did not see any reference to a washer pump.
NavigateNate
01-06-2018 08:45 AM
naiku
10-08-2017 05:46 PM
ligito
1999 to 2016 Super Duty
08-22-2017 11:28 AM
smashclash
02-21-2011 07:44 PM
Quick Reply: 08 Expy EL Limited washer pump location
