08 Expy EL Limited washer pump location - Ford Truck Enthusiasts Forums
2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Old 01-27-2014, 04:39 PM
brfan brfan is offline
brfan is starting off with a positive reputation.
Hello all... Need to replace my windshield washer pump and I was wondering if someone could tell me where it is located?
Thanks!
Old 01-27-2014, 06:06 PM
RI-Matt's Avatar
RI-Matt RI-Matt is offline
RI-Matt is starting off with a positive reputation.
Mounted to the washer reservoir.
CAUTION: When servicing the windshield washer pump be careful not to damage the windshield washer pump seal.
CAUTION: Do not operate the windshield washer pump before filling the windshield washer reservoir. Failure to do so may result in premature pump failure.
1.Remove the RH headlamp assembly.
2.Position aside the shield as necessary to gain access to the washer pump.
3.Disconnect the windshield washer reservoir hoses.
4.Disconnect the windshield washer pump electrical connector.
5.Remove the windshield washer pump.
6.To install, reverse the removal procedure.
Matt
Washer Fluid Pump akblackfoot 6.0L Power Stroke Diesel 6 12-14-2016 01:20 AM
2003 Ford Explorer Washer Fluid Pump mweaver644 Explorer, Sport Trac, Mountaineer & Aviator 2 01-26-2014 12:20 AM
74 f-100 back up and running need a washer reservoir David LaPell 1973 - 1979 F-100 & Larger F-Series Trucks 3 10-21-2013 07:37 PM
Rear Window Washer Big Sky Excursion - King of SUVs 12 03-17-2010 08:52 PM
Washer Pump Fuse? powerstroke72 1999 to 2016 Super Duty 6 01-16-2009 12:59 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
