Bear claws with original handles - Ford Truck Enthusiasts Forums
Old 01-27-2014, 01:48 PM
gdub's Avatar
gdub gdub is offline
gdub has a very good reputation on FTE.gdub has a very good reputation on FTE.gdub has a very good reputation on FTE.
I just put bear claws with the original handles in my F1 this weekend. The way I did it took a bit of thinking and fabrication but only cost me about $15 after the cost of the latches.
I cut down the original latch and switched them from side to side. This takes the guess work out of lining the handle up and makes connecting to the bear claw much easier. The lock has to be lined up seperately but it 's not too hard to do. Here's the pieces I used to add the lever to activate the latch and how they were assembled.
The latch plate fits right behind the window channel. The lock for the passenger side was welded to the top of the bear claw and the internal c shaped part was cut down and welded to the lock piece on the bear claw.
I had an old passenger door that I cut up to pre-fit everything, the latch point for the bear claw ended up just below the dovetail.
I used a cable to attach to the inside door handle. The passenger lock can only be operated with the key and the drivers will have to have an inside lever to operate it but that's only a minor inconvenience for having smooth operating latches. Still have a tiny bit of adjusting to do and need to get the lock cylinder back in, but they work like a charm so far.
Old 01-27-2014, 09:26 PM
snook715's Avatar
snook715 snook715 is offline
snook715 is starting off with a positive reputation.
excellent write up. I was hoping someone would do something like this because I dont think i want to spend a ton on the bolt in kit.
Old 12-05-2014, 03:30 PM
54-F100's Avatar
54-F100 54-F100 is offline
54-F100 is starting off with a positive reputation.
Great info
Thanks for sharing. It looks like a job well done.
You've hopefully been using them often....How are they working?
Old 12-05-2014, 04:05 PM
mustangmike6996's Avatar
mustangmike6996 mustangmike6996 is offline
mustangmike6996 has a good reputation on FTE.mustangmike6996 has a good reputation on FTE.
Awesome deal
Old 12-05-2014, 06:17 PM
gdub's Avatar
They work really well, it was well worth the trouble.
Old 12-05-2014, 07:21 PM
jmerson jmerson is offline
Old Timer
jmerson is starting off with a positive reputation.
Gary,
What brand of Bear Claw did you buy?
Jim
Old 12-05-2014, 10:41 PM
gdub's Avatar
They were just some of the large ones off of e-bay. Can't remember the brand.
Old 12-06-2014, 10:33 AM
rhopper's Avatar
rhopper rhopper is offline
rhopper has a good reputation on FTE.rhopper has a good reputation on FTE.
I used the small latches from Rocky Hinge and adapted to the stock hardware also, but my method was different. That said, I used bar stock for the links, attached with bolts, nylock nuts and nylon washers between the pieces for smooth operation. It works, but I can hear some rattling inside the door. You can only tighten the bolts so much before the joint binds. My long term solution is to change all the links over to rod ends. I'll swap the bar stock for threaded rod with rod ends. You can tighten the attachment bolts without fear of binding. Speedway carries a great selection of rod ends, and they're really not the expensive.
Gdub's 1951 panel build gdub 1948 - 1956 F1, F100 & Larger F-Series Trucks 54 02-10-2016 10:43 AM
'70 F100 CV IFS/TBird IRS Build elgemcdlf 1967 - 1972 F-100 & Larger F-Series Trucks 276 07-22-2015 11:11 PM
1962 F100 Restomod 62UniFORD 1961 - 1963 F100 Unibody 10 01-12-2014 02:44 PM
picture test harrisford User Gallery & Picture Display 3 07-16-2011 08:09 PM
2010 Daytona Turkey Run Photos GreatNorthWoods 1948 - 1956 F1, F100 & Larger F-Series Trucks 17 12-04-2010 08:27 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
