Transmission Cavitation? - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Old 06-28-2003, 10:02 AM
79CEEJAY's Avatar
79CEEJAY 79CEEJAY is offline
79CEEJAY is starting off with a positive reputation.
This is a follow up to my previous Vibration post. My buddy sat in my idling truck yesterday to feel my "vibration". He said it is my transmission fluid "gone bad" and the pump is cavitating causing the vibration. I have to agree that it is a surging vibration and it is not the engine. He suggested we change the fluid and filter and he is confidant it will go away. He said he had a similar problem with his old E4OD and changing the fluid helped. BTW the truck has 22,000 miles on it now. Anybody ever heard of this? I know there are some tranny experts out there!
Old 06-28-2003, 11:49 PM
cookie88's Avatar
cookie88 cookie88 is offline
cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.
I'm no tranny expert, but that seems a bit far fetched to me.
It should be pretty easy to diagnose if that is the problem. If it were pumping that much air you should be able to pull the dipstick with it running and see pink foam instead of oil.
Mechanic doesn't recommend FW-16 Winmagbar 1994.5 - 1997 7.3L Power Stroke Diesel 64 02-18-2016 08:59 AM
Lookin for an IDI. 85F350IDI Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 15 11-27-2014 10:49 AM
Bad Bad Vibration cornking Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 10 06-06-2012 08:49 PM
Cavitation Upon Takeoff Under Load Grodyman 6.4L Power Stroke Diesel 14 08-02-2010 12:59 AM
Vibration starting at 15mph whf 1999 to 2016 Super Duty 5 07-27-2010 01:11 PM
Tags
cavatation, cavitate, cavitating, cavitation, f150, fluid, ford, transmission, transmissions
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
