Anyone removed the roof? I am having troubles getting to the spot welds.
Pulling my roof to replace or shave the drip rails. I know its a lot of work, but I want the rust gone, not just welded over and hidden for a few years until it rears its ugly head again.
The sides and front are pretty easy to drill out (I may even just cut the welds out with the grinder and cut the lip off the rail). The problem is at the back of the cab. I plan on welding the seam above the window so I could cut it across the seam as a last resort. I would much rather prefer to drill the spot welds, I just can't figure out how to get my drill in there!
If your cab is rotted to the point where the seams are all falling apart, you're likely in the market for a batter, donor cab. There's lots of solid cabs around still. But if you're seeing benign rusty coloring and thinking you have a problem, you're going to make a bigger problem out of it trying to "fix" it. My 2c. Can you show us your concerns?
I should also point out several of the welds had rusted and popped on their own as I pried the two sections apart, which made it a little easier. Be careful you don't damage it too much, it might be hard to get the seam to line back up and close when you're done. I had problems with the two short cowl seams.
I use a spot weld chisel made by Steck...here is a link to one on ebay: http://www.ebay.com/itm/Steck-Manufacturing-20015-Seam-Buster-Spot-Weld-Chisel-/331079866984?_trksid=p2054897.l4276The trick is to insert the blade into the seam and then tap the back of the blade with a hammer to cut the welds. If you use this tool you will finish the roof seam job in less time than it would take to grind out just one spot weld...AND you will end up with a much better seam/flange.
I use a spot weld chisel made by Steck...here is a link to one on ebay: Video Link: http://www.ebay.com/itm/Steck-Manufacturing-20015-Seam-Buster-Spot-Weld-Chisel-/331079866984?_trksid=p2054897.l4276 The trick is to insert the blade into the seam and then tap the back of the blade with a hammer to cut the welds. If you use this tool you will finish the roof seam job in less time than it would take to grind out just one spot weld...AND you will end up with a much better seam/flange.
I didn't have any fancy tools so I used an old wood chisel and that work great. I even used it on the floor when I removed it for channeling. My original top had some pretty bad dents in the top and some nasty rust.
_______________________________________
48 Ford F1 - Darkside
46 Ford Tudor - Street Rod
"It's amazing how big of a Chevy you need to replace a Flat Head"
Who is putting on a fiberglass roof? Mine is steel and it is welded at the seams from the inside.
