2008 5.4 fluid leak
2008 5.4 fluid leak
Well got a new issue now. Noticed last night that I have a leak of some sort from the front of the engine. I have the 08 5.4 4x4 with 70k miles for the background info. The leak is coming from the front of the oil pan area unless it's running down the engine from somewhere I can't see yet. The fluid appears to be more like power steering. My oil is at the end of it's cycle so it is a little dark but the fluid leak is clear to a slight yellow and pretty thin in consistency. I've rubbed it between my fingers and the texture does not feel like oil. First I wanted to see if you guys have had a similar leak before I really start tearing into things and do you think it's possible to have power steering fluid leak that far forward on the engine? I've checked the fluid levels and they appear fine but this leak did just start and came on pretty quickly. I plan to take a photo tonight and re-post that. Have you guys had your oil pan seal to start leaking because I know that's pretty rare on most vehicles but nothing seems rare on this vehicle.
Quick question. Since we no longer have radiator caps what's the easiest way to check the fluid level in the radiator? I squeezed the upper hose and you could clearly hear the fluid gushing around. The expansion tank was a little low. Gone are the good ol' days when you could take the cap off and look into the tank.
Pretty sure it's the water pump. Noticed a the fluid is around the bottom pulley at the front of the engine. So I figure the fluid if leaking from the pump going behind the pulley and onto the oil pan. I plan to buy a new pump and seal (plus serpentine belt) and change it out this weekend. If that solves the problem I'll let you know.
nascar_20
03-12-2008 09:04 PM
