2V or 4V 351C
2V or 4V 351C
Evening team,
I'm looking at throwing a manifold and Holley at my aussie built '81 SWB. But I'm not sure if I have a 2V or a 4V.
At the moment I'm assuming it's a 2V due to the 2 venturi carb. The previous owner said that it's all origional (it looks it too).
Is there anything else I can look at without pulling the manifold off to tell what it is?
Also it's currently tuned to run on gas, I want to tune it to petrol and ditch the gas,along with updating the ignition. Any manufacturers I should avoid?
Cheers and beers....
Hi, the numbers stamped on the corner of the cylinder head was misleading when trying to determined externally if the engine is large or small port because post 73 4V engines were small port with a cast 4bl manifold. If yours is original it will be 2V. For petrol based systems, any of the major manufacturers dual plane plenums will be ok, personally I have always had a good run with Edelbrocks if sticking with LPG then general consensus is stick with single plane. Regards ignition, steer away from rubbish like Pro Comp and no name eBay specials and stick with mainstream such as MSD or Mallory etc.... Summit are a great source...Enjoy!
jarrettseiple
06-14-2015 09:58 PM
76BigBlock
30
09-14-2011 01:35 PM
