On Vacation, Need Help
So, drove the EX 14 hours to Orlando last night. It ran beautifully and I was averaging 15.8 mpg at 75-77 mph down I75 through KY and TN. After filling up just north of Atlanta the truck felt a little sluggish and fuel economy slowly started to drop. When we stopped for lunch (resort room not ready until 1), it wanted to surge at stop lights. After lunch we had a five mile drive to the condo and it kept up the surging when stopped and idling. Unloaded our gear and I hooked up the SCT to check for codes, nothing there. Hooked up torque pro and no codes shown there either.
I took the EX for drive after switching tunes and watched FICM and ICP (psi not voltage) along with IPR. FICM stayed steady at 48.5, 13 and 13. ICP at idle was 650+\-20 and IPR was between 18% and 20%. The surge would bump idle rpm around 100rpm. I'm sure the falling mpg and the surge are related. Someone give me something to look for before I freak out! Everything I've read of these symptoms point to ICP, it is a new Ford part after code P2285, very small amount of oil in plug. Is it the wiring?
Is it possible the tune had an issue that didn't show previous to the fill up? I'm guessing no, but I filled again after that stop to top off when my brother had to get gas, hold my hand and tell me it will be okay!
Could be poor quality fuel. Take sensor readings with factory program. So unload the programmer and diag. purposes because the IPR is too low for idle. It had a 7.3 one time with a bad EOT sensor pigtail. It would randomly loose connection and the ECM would be the oil temp go from 180 to -40 and back and would surge in the mean time. Watch ECT EOT and I would clean the IAT2 and EGR valve if new fuel does not clear it up.
Posted actual IPR numbers from Torque Pro above, didn't realize it saves it if you don't exit the program. I removed the Street tune and loaded another, no surge but the engine had cooled completely before I was able to run it again.
Unfortunately don't have a 32mm socket with me to replace HFCM filter.
