Heater Blower motor not coming on
Just tried to turn the heater on first time in 5 years truck has been a project heater wasnt removed but all wires under dash and under hood were " cleaned up " and re wrapped by a previous owner. I have found a few problems that he hid in the taped up looms so im just looking at where to start trying to narrow down the culprit before I replace the blower.
1979 f250 4x4 no ac
1979 f250 4x4 no ac
Take a close look at the firewall, (top edge of the pic, to the right of the voltage regulator) do you see any way to remove the motor with cage attached to it? even with out the cage attached there is a flange in the way.
Sorry to say nope, all you see at the firewall is the motor sticking out, you have to pull the heater box.
Non a/c truck easy, pull the glove box and do a pic tutorial for the group....might as well replace the heater core since you are right in there.
If not it will start to leak next week...at least that is my luck.
73M6M
05-22-2012 09:43 AM
