6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Rad replaced?
Old 01-26-2014, 06:15 PM
Vinford's Avatar
Vinford
Vinford is offline
Rad replaced?
Have been reading my Oasis report and I see they have changed the rad on my truck 4 times.
Anyone got any ideas why it would need changing 4 times?
I don't want to hsave to do it a 5th time iof I can help it.
Theres 6 pages to my Oasis report this truck almost makes me think its a candidate for a lemon law or something?
Old 01-26-2014, 06:54 PM
slowmans's Avatar
slowmans
slowmans is offline
Yikes 6 pages!!
The 08's had real problem with radiators, the 09/10's not so much, something about the way they mount I believe...
Old 01-26-2014, 09:39 PM
longview1's Avatar
longview1
longview1 is offline
You'll do it a 5th time. Just a matter of when. The oem rads are junk, plastic end tanks crimped on. Changed it for the 5th time (when it comes) and last time with an all aluminum one.
Old 01-27-2014, 10:21 AM
blackeyed1's Avatar
blackeyed1
blackeyed1 is offline
I take it you bought it used? I'd say you wouldn't stand a chance filing under lemon laws at this point. But what do I know. I can't imagine having 4-5 new radiators, and other "fixed" issues. I'd put a match to my truck by now. Mine is stock and only changed one radiator hose since Nov 08. But I get a nervous gut feeling every time I drive it. Hate that feeling even with extended warranty.
Old 01-27-2014, 10:37 AM
bubbasz1's Avatar
bubbasz1
bubbasz1 is offline
What else is on the list, other than the radiators.
Old 01-27-2014, 01:50 PM
ljutic ss's Avatar
ljutic ss
ljutic ss is offline
The aluminum aftermarket radiators have also been reported to fail. I only went through 3 radiators in 84k and what the tech and service manager explained to me is the cause for failure starts at the thermostats. They allow for a pressure spike to happen and this is what makes radiators to leak.
Old 01-27-2014, 07:57 PM
Vinford's Avatar
Vinford
Vinford is offline
Its long but ill try and keep it short...
First 3 things were cosmetic , trim and wheels scratched.
Recall PCM recalibration
Howling noise front end.
Replaced driveshaft.
Replaced rad
Tranny hard shifting recalibrated
Overhaul rear diff.
Replaced rad
Rear axle seal
Fix backup lights
Engine loosing power.
Reprogrammed PCM, TCM,ICM and fuel tested pressure
Found leaking CAC tube.
Drivers seat recall
Lots of white smoke cant see vehicle behind.
Reprogrammed PCM/TCM IC
Loud bang and turbo quit working.
CAC hose blown off.
Exhaust flex pipes leaking.
Removed cab and fixed exhaust.
Recall 11B23
Coolant leak replaced water pump and front cover.
Replaced rad.
Updated degas bottle.
Lose of power Thermostat stuck open replaced.
Front cover leaking oil. Replaced front cover.
Engine light on. Took cab off and replaced High pressure pump , reset fuel strategy.
Brake calipers seized Replaced everything on both sides front.
Leak at Can Sensor
Replace right side ball joints.
Replace right side tie rod end.
Replace steering box.
Exhaust smell in cab. Manifold bolts broken in head. Extractor broke off in one hole, had to be ground out and refilled.
Coolant leak. Heater tube leaking and replaced. Replaced rad.
Took cab off to take out broken manifold bolt.
Took off head to be worked on.
And since Ive had it I replaced the front drive shaft and ujoints. $700
Did the delete $1200 and bought tires $1200
This truck sounds like a project truck not my good daily driver.
Ive got a 79 F-250 sitting in the yard that was going to be my project but I guess this ones taking over.
Old 01-28-2014, 08:37 AM
blackeyed1's Avatar
blackeyed1
GEEEEZZZZ!
Old 01-28-2014, 09:49 PM
Vinford's Avatar
Vinford
Vinford is offline
Something I forgot to add was I asked for this info when I bought the truck.
The dealer gave me the first page and said "not much on it".
Old 01-28-2014, 10:24 PM
longview1's Avatar
longview1
There's only one on the market at this point that Im aware of. I also havent heard of any failures, not to say there isnt I just havent seen/heard/read about it yet.
They can say what they want but they all leak from the same spot (end tanks) the aluminum ones wont have that problem.
Old 01-28-2014, 10:30 PM
Vinford's Avatar
Vinford
Vinford is offline
What was your aluminum one worth and where did you get it?
I think I read somewhere you changed it yourself right?
Old 01-28-2014, 10:35 PM
longview1's Avatar
longview1
Just under $800 plus another $100 for shipping (ordered from Summit). Mishimoto radiator. Alradco has one in the works as well. Only two Im aware of.
Yes I replaced it myself.
Old 01-29-2014, 10:52 AM
ljutic ss's Avatar
ljutic ss
You can add a 3rd aftermarket radiator Mfg. that are making replacements for the 6.4 and probably the 1st one to offer one. Vista pro #438400 also if you do a search under "aftermarket radiator" and scroll down to post #13 you will see a poster say he is on his 3rd mishimoto radiator.
Old 01-29-2014, 11:11 PM
longview1's Avatar
longview1
That vista pro is not all aluminum, it has plastic end tanks according to the description.
I'll take a look for the thread you mentioned about the mishimoto, I'd like to know what failed.
Old 01-29-2014, 11:27 PM
longview1's Avatar
longview1
I can't find the thread you mentioned. Can ya post a link please?
Quick Reply: Rad replaced?
