Oil around spark plugs threads
It sounds to me like the oil is on the OUTSIDE of the sparkplugs and likely leaking down from the rocker arm cover. I would suggest you use your air hose to blow out any debris from around the plugs before you remove them (a good practice anytime you want to remove your sparkplugs) then remove the plugs. Wirebrush the threads, check the gap, and if not too eroded, reinstall them with a bit of never-seize lube on the plug threads. Then put a dab of dia-electric lube on the wire end of the plug and re-install their wires. It might be a good time to test your sparkplug wires for excessive resistance. If they check out good, fine; if not, time for a new set of sparkplug wires.
If it was bad valve guides or piston rings letting oil into the combustion chamber, the electrode gap and end of the plugs would be oil-fouled.
BarnieTrk
BarnieTrk
william16339
09-12-2014 06:50 AM
runinbear
16
12-31-2007 01:11 PM
