PO'd at the PO Ignition system question HELP PLEASE
Morning y'all,
Apparently i am a gluten for punishment. When i got my 77 the under hood wiring by the distributor was hacked so to get it home I wired in a points distributor, it ran and ran well so i left it there. Long story short i sold the truck to my buddy who decided that points were old and no good when he couldn't set his new set properly. Well he cut the wires to the coil and pulled the distributor so i am now helping him try to put in an original duraspark unit. WE have the ICM hooked up to the proper plugs and all the wires colors from the engine harness matched the distributor plug wire colors so those we soldered and heat shrink so that plug is back. My issue is the color wire my wiring diagram shows as being coil (-) is green/yellow stripe and has 9.6v flowing through it. SO could somebody please guide me to what dang wire i need to hook the coil (-) to thank you.
tx_bump_72
12-11-2015 02:31 PM
millboroman
12-19-2011 06:43 PM
heybrent
1978 - 1996 Big Bronco
08-08-2002 10:47 PM
Bruce in SC
01-23-2002 12:34 PM
