Choke Cap Question
The image below shows one gasket, #9871, but doesn't have the choke baffle plate your kit came with. And, I know that 9871 is a gasket because I see it in drawings of the Carter 1bbl in the parts catalog. But they don't show a 4100 so I had to turn to a Google search.
But this one shows one gasket and the choke baffle plate. (Click on the link to go to a page where you can zoom in on the drawing.)
Thanks for taking the time to do the research, Gary.
I am not sure if I understand this. Is the choke baffle plate a metal plate, or does that refer to a gasket? My Autolite 4100 used the stat cover gasket only. (But the Autolite 4100 never used an electric choke cap, while the later model Motorcraft 2150s did.) I assembled the electric assist choke cap on my Autolite 4100 with only the upper gasket in my original post and it seems to work fine.
What is the purpose of the choke baffle plate? Do the electric choke caps need this extra gasket?
oblivionnewtonjohn
02-06-2015 07:07 AM
Cienega32
12-22-2011 06:54 PM
