bought my IFS and IRS donor car today! - Ford Truck Enthusiasts Forums
Old 01-25-2014, 09:15 PM
Trey_Morgan's Avatar
Trey_Morgan Trey_Morgan is offline
Trey_Morgan is starting off with a positive reputation.
Today I bought a 1976 Jaguar XJ-6 Complete car for the very fair price of $375.00 it has the original engine transmission and 146k miles.
What do you guys think!!
Old 01-25-2014, 09:41 PM
raytasch's Avatar
raytasch raytasch is online now
Old guy with old toys
raytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant future
IMO, a good buy. Should be able to get the parts you need and make a profit on selling other parts.
Old 01-25-2014, 09:42 PM
56panelford's Avatar
56panelford 56panelford is offline
Posting Legend
56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation
Think you got a bargain and should be able to recope and profit with the body parts, looks very rust free.
bobj49f2's Avatar
bobj49f2 bobj49f2 is offline
bobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud of
The hood doesn't seem to shut quite right and the rear door and quarter panel don't seem to match the rest of the car. Other than that it looks OK.
Oh yeah, for $375 you got a pretty good deal. You should be able to sell the parts you don't need and break even. The IFS won't cost you a dime.
Old 01-25-2014, 09:46 PM
Quote:
All the removable panels are rust free but the rear quarters are rusted from it sitting under a lean to for the past few years. I hope to get as much sold as possible before the boss starts pushing me to get it out of the driveway and I have to take it to the scrap yard!
Old 01-26-2014, 05:51 AM
49willard 49willard is offline
49willard has a great reputation on FTE.49willard has a great reputation on FTE.49willard has a great reputation on FTE.49willard has a great reputation on FTE.
Congratulations, good find! You have a series 2 XJ. It should have the 4 piston (not 3 piston) front caliper brakes with vented disks. Given the mileage, you will want to check the IFS for wear/rebuild. It may have gone thru rebuild.
Old 01-26-2014, 06:47 AM
seaves46 seaves46 is offline
seaves46 is gaining momentum as a positive member of FTE.seaves46 is gaining momentum as a positive member of FTE.
Make sure you keep the windshield wiper setup , they are great to adapt to anything .
Old 01-26-2014, 08:09 AM
Marauder2004's Avatar
Marauder2004 Marauder2004 is offline
Marauder2004 has a good reputation on FTE.Marauder2004 has a good reputation on FTE.
That's a good price, just a notch more than scrap value. How could you go wrong?!
Old 01-26-2014, 08:18 AM
douglpr42 douglpr42 is online now
douglpr42 is gaining momentum as a positive member of FTE.douglpr42 is gaining momentum as a positive member of FTE.
in ontario canada you would pay more than ten times that for a rust bucket jag. great deal hope to see pics of build .
Old 01-26-2014, 02:11 PM
das54's Avatar
das54 das54 is offline
das54 has a good reputation on FTE.das54 has a good reputation on FTE.
a funny thought came to me. Somewhere on a Jag forum they are staying this is a travesty, it should be saved and restored. Someone rescue that XJ-6 from those rat rod cannibals.
Old 01-26-2014, 02:21 PM
Posting Legend
They should consider it a compliment.
Old 01-26-2014, 05:45 PM
kstones63 kstones63 is offline
kstones63 is gaining momentum as a positive member of FTE.
I assume that you are going to use the Jag IRS?
I am in the process of putting one in my son's 63 F100 right now. We are using the front IFS and the rear IRS in his truck.
Snow White LTD in northern California has a nice mounting kit for the IRS. It is kind of pricey but it makes it an easy install.
I used their kit that has the 3" drop in the center and I should have use the straight crossmember. The rear sits lower than the front so now I am in the process of cutting it back out and raising the frame up higher to compensate for the proper ride height. If you are want to notch the front crossmember into the frame, you could get the truck lower. I had oil pan clearance problems so I needed to raise the back up a little.
The IRS is a Spicer rear end and Dana 44 gears can be put in the rear so you have a pretty good choice of gears to use.
Kevin
Old 01-26-2014, 06:44 PM
qmanconfused qmanconfused is offline
qmanconfused is starting off with a positive reputation.
remember to keep the steering column and all the stuff attached to it incl. the rag joint
qman
I bought a similar 72' and should have kept that stuff
Old 01-26-2014, 06:59 PM
acudanut acudanut is offline
acudanut is starting off with a positive reputation.
That is a very good price, I had to pay couple hundred more for a '83 couple of years ago. Unfortunately not much demand for jag parts around here, still have some good parts even a running motor.
Old 01-26-2014, 08:49 PM
Took some time today to start on the tear down of the jag today. pretty simple so far I plan on getting the suspension out from under it by next weekend. I plan on keeping the following parts for myself to try and graph into my F-1;
IFS
IRS
Power steering system
Steering column
Seats
mirrors
fuel doors
wiper assembly
Center consul
brake and gas pedals
windshield washer system
I would feel worse about tearing this car apart if it had been a running and driving car but it has sat for the past 10+ years and from what I can see the only thing wrong with it was the starter solenoid. The starter just clicks when you turn the key but if you jump the started with a remote starter switch the starter turns the engine over. the fuel in the tanks is disgusting so I didn't try to get it running. here are a few pictures of what I got done today!!
my '51 is quickly turning into a mutt ( In a positive upgraded kind of way) Trey_Morgan 1948 - 1956 F1, F100 & Larger F-Series Trucks 0 07-13-2014 05:13 PM
is a C-notch or step notch even needed here??? Trey_Morgan 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 06-28-2014 09:15 PM
1951 F-1 rear axle swap snafu Trey_Morgan 1948 - 1956 F1, F100 & Larger F-Series Trucks 12 06-27-2014 07:47 PM
I might be in over my head on this welded jag ifs instal. :/ any help would be great. Trey_Morgan 1948 - 1956 F1, F100 & Larger F-Series Trucks 35 06-23-2014 04:44 PM
1951 F-1 triangulated 4-link design. Trey_Morgan 1948 - 1956 F1, F100 & Larger F-Series Trucks 7 06-17-2014 09:32 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
