1996 f-150 xl
Old 01-25-2014, 07:40 PM
LJ280's Avatar
LJ280
LJ280 is offline
1996 f-150 xl
Hey guys, been an eventful day here.
I went out to Altona Manitoba this morning, bought myself a 96 F-150 XL.
Will post some pics when I get to my computer.
Love this truck so much It has a 300 I6 and a
5speed standard transmission only a 2WD though.
Have driven about 170km today on a little less than 3/8 a tank.
Old 01-26-2014, 01:53 AM
LJ280's Avatar
LJ280
LJ280 is offline
Old 01-26-2014, 02:46 PM
Bright Regatte Blue's Avatar
Bright Regatte Blue
Bright Regatte Blue is offline
Nice truck you have there. What are your plans for it?
Old 01-26-2014, 05:14 PM
warren561's Avatar
warren561
warren561 is offline
Looks sharp! Identical to my truck except for the topper and the chrome bumper!
I-6 and 5sp and 4x2 is great for fuel mileage.
Old 01-26-2014, 08:34 PM
LJ280's Avatar
LJ280
LJ280 is offline
Thanks Well first thing to do is take her to a shop get a few small things for a safety, nothing much been quoted at $370.00
Then get plates fix the rust when the weather is nicer, sort of want a 2" lift so i can put the 33" tires from my 78 on it thats just a maybe though.
Old 01-26-2014, 08:36 PM
LJ280's Avatar
LJ280
LJ280 is offline
Thanks its in really good shape for the year especially around here got a good deal on it too
It's excellent on fuel, gets around the same mpg if not better than my 06 ranger with a 3.0L auto.
Old 01-27-2014, 07:38 AM
Bright Regatte Blue
By my geographic standards, your truck is horribly rusty. (We're lucky enough to have scads of rust-free OBS Fords out here in California.) As for the 33s...I've noticed a lot of threads lately concerning poor MPG, and larger tires have been culprits. What gear ratio do you have?
Old 01-27-2014, 09:38 AM
LJ280's Avatar
LJ280
LJ280 is offline
The roads out here are sanded and salted like crazy……
The 33's are only just an idea, as for the gear ratio i have no idea.
Travelling at 100kph/60mph in 5th gear my tach reads 1550rpm.
Old 01-27-2014, 09:49 AM
Island Time's Avatar
Island Time
Island Time is offline
The door tag (drivers side b pillar) contains a bunch of codes indicating how your truck was initially equipped, including the ratios. Post the codes, or a clear photo of it and somebody will pop up with the info.
Old 01-27-2014, 11:01 AM
Bad Bad Leroy Brown's Avatar
Bad Bad Leroy Brown
Bad Bad Leroy Brown is offline
Your first "mod" should be about 5 or 6 hundred pounds over the rear axle based on the snow in those pics. nice lookin truck.
Old 01-27-2014, 11:29 AM
mefast's Avatar
mefast
mefast is offline
A good set of snow tires is all you need. Mind you, I likely have about 100-200 lbs of snow and ice in my bed. His topper should be giving him enough weight.
Old 01-27-2014, 11:37 AM
LJ280's Avatar
LJ280
LJ280 is offline
This is what i found seems to be a 2.73 from what i can find.
Old 01-27-2014, 11:41 AM
LJ280's Avatar
LJ280
LJ280 is offline
Thanks love this truck
The snow isn't that deep around here right now. Parked in a small 12" drift at work, when I went on lunch I just crawled through it in 1st gear no problem
I was actually gonna sell the cap in a bit. Have a headache rack from my fathers old 79 ford I want to put on.
Old 01-27-2014, 06:07 PM
Bright Regatte Blue
About all I could figure out from your door sticker is that you have a 5-speed, 5310 springs up front, and 5560 out back. Looks like your axle is a 2.73:1 open diff--which would explain your low RPM at 100 KPH. (My truck, in fifth gear at 65 MPH, turns over 2,500 RPM.) I'm still looking into your paint color code.
Old 01-28-2014, 08:34 AM
spacegrass's Avatar
spacegrass
spacegrass is offline
Manufactured 5/96... That's one of the last to roll off the line. Very sweet truck.
GOLFER1ESS
11-19-2013 11:34 AM
adamecelectric
07-29-2011 10:16 AM
Jrich1
2004 - 2008 F150
06-09-2006 06:30 PM
polarbear
General Automotive Discussion
34
02-17-2006 05:35 PM
krb407
05-29-2003 08:12 PM
Quick Reply: 1996 f-150 xl
