Rear end universal joint
#31
slip yoke might be fine see albuq f-1s comment. How long is the yoke? You need about 2" past the seal inside the trans throughout the motion of the rear axle.
In other news... you MIGHT want a 1330 x 1350 conversion U-joint. I have the same type in the rear of my mustang. The 1350 is 1 3/16" and the 1330 is 1 1/16"
You can easily overtighten the U-bolts. 30 ft lbs is about all they should have. Getting this right is serious business... last thing you want is an axle letting loose at highway speed.
#32
I would get a longer driveshaft, bushing engaged or not. Do it once and do it right. If you have a welder and a grinder it is not hard to shorten a driveshaft if you get another one that is too long, I have pics of the shaft I made for my 47 caddy and I have always done it the same way. Low buck and works fine at 80MPH, no vibrations.
#34
#35
In other news... you MIGHT want a 1330 x 1350 conversion U-joint. I have the same type in the rear of my mustang. The 1350 is 1 3/16" and the 1330 is 1 1/16" You can easily overtighten the U-bolts. 30 ft lbs is about all they should have. Getting this right is serious business... last thing you want is an axle letting loose at highway speed.
#36
Typically at ride height the driveshaft shops recommend approx. 1" of exposed trans yoke, free travel, so it depends on how long your tailshaft sticks out of the trans on whether that is to much or not, And like Ross said you want to be completely through the tailshaft bushing.
And just for info 30 ft/lbs is to much torque for that u-joint u-bolt. Here is a good chart.
Randy's Driveshaft Service - Torque Specifications
#37
You might want to wait until the truck is pretty much all together so all the weight is on the suspension. The required drive shaft length could change.
#38
Received 4,132 Likes
on
Inland Empire Driveline Service :: Driveshafts :: Ordering Driveshafts (One Piece Driveshaft)
Mine had been ordered here and this is how they wanted it measured.
#39
. And just for info 30 ft/lbs is to much torque for that u-joint u-bolt. Here is a good chart. Randy's Driveshaft Service - Torque Specifications
#40
It's really not OK, the chart shows 13 - 18 ft-lbs for a 1330. Excess torque/clamping force may distort the cup and prevent the rollers from functioning. The chart agrees closely with recommended torques for 5/16"-24 Grade 5 bolts.
#41
I dont have pics of when I did it in my truck but here is a pic of when I did it with my caddy. With the truck I didnt have a factory crossmember so I just layed a piece of steel tube across the frame to hook the straps to. No way would I run with more than 2" of exposed yoke even with the yoke all the way in the bushing, but that is just my opinion.
Here is the spacing in the truck I am building now, output shaft is about half way inside that rubber dust seal, so there is about 1" open yoke with the suspension unloaded. When the suspension is compressed the driveshaft moves away from the trans and there is about 2" exposed (going on memory, not at home now). I used a 6" long yoke from the T56 donor car.
#42
Cheers! t
#43
Otherwise... agree.... I put 30 out there as a general guideline not to exceed... as it was mentioned in the thread about tightening down a 1350 yoke to a 1330 u-joint until no gap was visible... had me concerned.
#44
#45
missing the key piece of info, that the U-bolt end is 1350, not 1330 and the correct torque is 24 ftlbs.
Ok, this U joint kicked my a$$ all weekend, but I *think* I have it right now. As you recommended, I got the 1-4635HD and it fits as well as I think it's gonna. The thing is, I can still see some daylight on the rear side of the bearing in the diff yoke. See the attached pic (the top of the pic is to the rear of the truck). I think the bearing sits on a tiny lip in the bottom of the differential yoke cup and that creates a smidge of a gap to the rear. Am I right about that, or am I making that up just so I feel better? There is no gap to the left or right side of the bearing. If the bearing were any wider, it would not fit in the left-to-right dimension of the yoke cup. Again, see the pic (the right side of the bearing is all that shows in this pic). Do I have this settled or am I off the mark still? Thanks! Tyler
Modern Driveline, Inc. - driveshaft
