1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Right turn signal/Brake light in-op
Old 01-25-2014, 12:47 PM
gtmustang00's Avatar
gtmustang00
gtmustang00 is offline
The multi function switch was replaced. The headlights work fine. The emergency lights/flashers work fine (aside from the passenger side rear). The running lights work fine (at all 4 corners). The brake light/turn signal for the passenger side rear does not work. Sometimes when the right or left turn signal is on it will stop flashing and buzz. Any suggestions? Any wiring diagrams i can look at? Thanks.
Bulb is good, i even put a new one in for good measure lol.
Old 01-25-2014, 01:00 PM
r2millers's Avatar
r2millers
r2millers is offline
If the bulb is good or replaced, I would check for good contact at the base. Clean up and put a dab of dielectric grease on the contacts to reduce corrosion.
Not too uncommon an issue, especially in moist areas.
Old 01-25-2014, 02:38 PM
gtmustang00
Update. I took it apart, there was a wire that had pulled out. Fixed that. We have brake lights, and flashers work at all 4 corners now. Running lights work, now we have no turn signals. Dash arrows aren't even lighting up now.
Old 01-25-2014, 02:53 PM
r2millers's Avatar
r2millers
With a wire pulled out, I bet it you might have blown a turn signal fuse.
Old 01-25-2014, 10:17 PM
gtmustang00
Diagnosed it to a intermittent flasher. New one solved the problem!
Kendall Driver
09-27-2023 01:41 PM
Bigdog8333
07-29-2019 03:59 PM
ryank59701
11-28-2015 10:19 PM
lilrobo
11-16-2013 02:45 PM
pyro225
04-27-2008 11:43 AM
Quick Reply: Right turn signal/Brake light in-op
