93 Ranger Splash Tensioner
I have a problem with the serpentine belt tensioner, on a 1993 Splash; 4cyl motor. The tensioner spring is frozen/stuck, so it is set to where it is. Tried to 'exercise' to free it up,,,,, that did not work, and sorta' rounded out the 3/8 square hole doing that. So,,, ordered an new tensioner assembly. I felt around the tensioner mount at bottom,, do not feel a bolt head,, so it must be flat head allen or torx bolt,,, correct ???? I am guessing this will be a real sweatheart to change, given the age of truck and natural corrosion,,, any help or hints will greatly appreciated.
The tensioner has a pulley but depending on your engine there may be 1 or 2 other 'idler' pulleys and it's a good time to check them all. I hope the repair goes well. Let us know if anything else comes up.
On my truck I ended up removing the grill, radiator, and fan off to get a good shot at the bolt (manual trans no a/c).
Some of the bolt threads stick through the back of the mount, try to get some type of lube in there.
I ended up having to drill the head off the bolt. Not fun at all.
Change your idler pulley while your in there. It's easy.
It is the 2.3 4 cyl,,,, no a/c,,,, stick shift,,, 2 wd,,, 93 Splash
This tensioner had sorta' stuck a while a go,,,, I sprayed some poheekum on it ,, then exercised it, I had it freed up,,,,,,,,,, but it got stiff again,, sprayed more stuff on it to try to free it again,, then thought ,,jeepers just get a new tensioner,,, I think I read it may be a 50torx that holds it on,,,,,,,,,,,,,,,, will spray everything I have in the shop on that bolt,, maybe it will come out ok,,,,,,,,,,,, 'gulp',,,,,,,,,,,
Thanks for all the tips,,,
Thanks J-S,,, this is my son's ole' bomber go-to-work truck, not real pretty but runs decent,,,, we put a new heater blower in it last Saturday, and when he started it to back out of garage,,, I heard the belt squeal a lil',, so knew right away that tensioner had mis-behaved again,,,, now he says the thermostat must be bad,,, trk will not get very warm,,, even with a cover over radiator,, it has been very $%&*@# cold this Jan, but still. So,,,,,,,again simple job,, not a lot of $$$,,,,,,but as is always the deal with older stuff,,,,, removing old bolts without breaking anything,,,, ugh,,,,,,,,,,,,,, more poheekum to soak 'em with is needed again ,,,, thanks guys,,,,
On the farm as a kid,,, our favorite poheekum was: Liquid Wrench
Now there is this stuff called: Freeze Off
WD-40 I always felt was more of a lube that penetrating product, but have used that,,
Marvel Mystery oil in a pump-squirt oil can , done that too,,,,
lot's of stuff available,,,,,,,,,,,,,,,, the best ,,, who knows ?
The best penetrating fluid is a mix of ATF and acetone. 'bout 50/50. There's a test on the web somewhere comparing several, and this inexpensive combo beat them all.
WD is not a good long term lube. It evaporates leaving little lubricant. It is "Water Displacing" == WD, originally designed to get water out of ignition components, and will loosen gummy things and work as starting fluid {ether?} for small engines. I've heard the latest mix won't start mowers, though. YMMV
tom
tom
93RangerXL4x2
03-06-2011 07:26 PM
jerrymlr1
08-19-2008 03:24 PM
