96 f150 4x4 front shock mount question - Ford Truck Enthusiasts Forums
Old 01-25-2014, 11:56 AM
captain1997 captain1997 is offline
captain1997 is starting off with a positive reputation.
Does anyone know if I can replace my front shock mounts which are Quad shock mounts with single shock mounts?
Mine are getting extremely rusted and Im wondering if I can change them over to single shock mounts without drilling holes.
If any one knows let me know.
I realize I could just measure but I have to purchase one to do any measuring.
And so happens I have 3 of these f150's and they all have the damn Quad shock.
And I dont see any reason to have 4 shocks on the front.I dont run a snow plow or anything.
Thanks
Old 01-25-2014, 12:02 PM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is offline
Diesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud of
Yes, they use the same bolt pattern.
OR, you can use the double shock mount but only run single shocks
Old 01-25-2014, 12:12 PM
Thanks Diesel Brad!
They look identical to me but I wasnt sure. Im going to go with the single shock mount.
I was just going to replace them with the Quad mounts and run single shocks but the Quad mounts are hard to find and also they are quite a bit more price wise than the singles.
Keep replacing things on this truck its going to be all new soon...LOL
Just replaced the rear shackles springs and everything with new and put in new 1 ton ford van springs, new ball joints axle joints calipers drums bearings, gas tanks.
Keep going Im going to get the urge to throw a new paint job at it!
Old 01-25-2014, 01:04 PM
broncoderek's Avatar
broncoderek broncoderek is offline
broncoderek is gaining momentum as a positive member of FTE.broncoderek is gaining momentum as a positive member of FTE.
What van were your springs from? The length (and width) were both right on?
Old 01-25-2014, 02:00 PM
the springs and shackles and all the bolts and bushings were out of a 95 e350 ford van which is the one ton (which compared to a one ton pickup is not really a one ton). I found them at my local salvage yard it was a utility van and the front end had been totaled out but the rear springs and shakles were brand new Ford OEM not even dirty and still wearing the Ford stickers with the stocking bar code.
I measured them up they were the same width and length.Bought everything for $75 bucks brought them home got out the torch and wacked off the rivets and throwed them on.
It only raised the rear slightly.
But I can definitely tell the difference when I haul my trailer or put anything in the back it takes a hell of alot more to make her squat!
One of my better cheap investments!
Old 01-25-2014, 03:12 PM
Great deal! That gives me more to look for since my rear packs have just about had it! Thanks!
Old 01-25-2014, 03:56 PM
glad I could help bronco! everything will bolt right in it took me about 3hrs by myself.
Old 01-27-2014, 09:15 PM
ATS Junior's Avatar
ATS Junior ATS Junior is online now
SPONSOR
ATS Junior has a very good reputation on FTE.ATS Junior has a very good reputation on FTE.ATS Junior has a very good reputation on FTE.ATS Junior has a very good reputation on FTE.
If your looking for measurements between the two I can give them to you. I have both in Stock so I can compare them both if you like.
Let me know!
-Junior
__________________
www.ATSsprings.com
Ask About our Ford-Truck Forum Discounts! (1-888-943-8287)
"We sell parts and experience"
Quad shock tower FordOwnerJoey 1987 - 1996 F150 & Larger F-Series Trucks 1 10-13-2015 05:52 AM
Front shock mount NW 150 1973 - 1979 F-100 & Larger F-Series Trucks 2 10-20-2013 01:35 PM
Dual vs. Quad Shocks? RangerHaywood 1973 - 1979 F-100 & Larger F-Series Trucks 6 06-22-2010 06:41 AM
4 Front Shocks? foliot 1987 - 1996 F150 & Larger F-Series Trucks 7 03-09-2009 02:54 PM
Coil springs for Quad Shock Option Harfend 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 1 12-17-2008 11:10 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
