2014 SD 6.2L questions.... - Ford Truck Enthusiasts Forums
6.2L V8 Discuss the 6.2L V8
Old 01-25-2014, 11:23 AM
Go Big or Go Home! Go Big or Go Home! is offline
Go Big or Go Home! is starting off with a positive reputation.
Now that I have had truck a month and have put 1000 miles on her, I am curious about a few things with this truck. I notice some kind of FAN kicks on when the truck is started and continues to hear it even when shifting gears and driving truck..Is this normal for this engine/SD. Also, the dreaded vibration at 45-50mph..I thought I got away from that from the F150 but it has the same characteristics at the exact same speed.. Do you guys have same with the 6.2L? Mine is the 172WB so I am wondering if it is because I got long bed,,same with F150 had the 6.5 bed... I am enjoying the new SD, sounds great, 13 mpg's all city. Can anyone offer any feedback? Before I go racing off the dealer (2 hrs away) just curious what others are experiencing..
Old 01-25-2014, 12:12 PM
GASPIG88 GASPIG88 is offline
GASPIG88 is starting off with a positive reputation.
My 2012 does it, my dads 2013 does it, my bosses 2011 does too
Old 01-25-2014, 01:36 PM
Quote:
Does what? The fan noise or the vibration? Or both?
Old 01-25-2014, 05:36 PM
Quote:
Just the fan now, the vibration quit after the first month or so.... sorry I failed to mention that in the last post.
Old 01-25-2014, 05:47 PM
BigMix's Avatar
BigMix BigMix is offline
BigMix is starting off with a positive reputation.
No vibration. It rides smooth until I hit a bump then it will shake you silly. I haven't notice any fan noise, but if I could get 13mpg in the city I would gladly have a fan blowing. Sometimes when it is cold it does have a louder than normal whirring noise.
Old 01-25-2014, 06:29 PM
projectnitemare projectnitemare is offline
projectnitemare is starting off with a positive reputation.
Being both of you have CCLB trucks, do either of you get a pulse from the ABS while making turns? Say like 15mph and hit a bump in the road, it gives a quick hit of the ABS like spining a tire or sliding. The dealer is telling me it's characteristic of the truck. My fan is loud also, most mechanical fans are.
Old 01-25-2014, 07:44 PM
22rimfire 22rimfire is offline
22rimfire is gaining momentum as a positive member of FTE.22rimfire is gaining momentum as a positive member of FTE.
Mine is a CCSB, but I do get the pulse on the brake while turning slowly on a downhill corner by my house. I don't don't have either of the other two issues. Yours have the two piece driveline right? I have heard some of those will vibrate under certain conditions. Seems like I recall that a spacer that lowers the driveline joint helps? Good luck.
Old 01-25-2014, 10:51 PM
RBALAN RBALAN is offline
RBALAN is starting off with a positive reputation.
Not sure about the vibration as I have never noticed any, but I have heard the fan noise.
As far as the brake pulse goes, see if it does the same thing with traction control off. My truck will do this turning into my neighborhood with it on but not when I turn it off, so I'm surmising its the elocker de-activating.
Old 01-26-2014, 08:47 AM
Thenewboss's Avatar
Thenewboss Thenewboss is offline
Thenewboss has a good reputation on FTE.Thenewboss has a good reputation on FTE.
My fan is loud, my injectors are loud, the engine ROARS when itís cold. I had serious bump steer but the new shocks and steering stab fixed that. If AdvancTrac is on and the tires become ďun-plantedĒ the ABS will kick in, mine does on bumpy or rough roads, more so under hard braking. 2 sets of tires and 56,000 miles and I still get a vibe at 45 and 65, Iíve learned to live with it plus the new shocks and airbags dampen it out for the most part. The adaptive learning on this thing is amazing, if you donít like the way itís driving, reset the computer and try something else, the truck will operate in accordance with your driving habits. It is a noisy truck but once you get used to it youíll barely notice it.
Old 01-26-2014, 11:00 AM
No bump steer
no vibration at any speeds
Just a loud fan when its cold and this ticking/tacking that lead to the up coming engine replacement
Happy about getting a shining new 6.2
As for the ABS.... never had an issue but i will keep an eye on it
P.S. I spoke to my dad and his didn't have vibration at all... just the fan noise
I'm thinking about that livernois cam shaft kit that'll maker scoot
Old 01-26-2014, 11:18 AM
Powelligator's Avatar
Powelligator Powelligator is offline
Powelligator is starting off with a positive reputation.
Quote:
YES! I have been thinking that this is "just me", but my truck (SuperCab Long Bed) does this exact same thing. Trouble is, I can't reproduce it, in that if I get the "ABS bump" making a turn and I go back around and retrace my path it won't do it a second, or a third but might do it the fourth time around. Yeah, try taking that to my dealer, I'll get laughed out of the service bay.
My fan comes on loud when it's cold, but after it warms up it's silent.
-Joe
Old 01-26-2014, 03:05 PM
ok, great the fan noise is normal,, I can check that off. The vibration is a issue, I will bring to dealer,,i bet it is driveshaft, either needs grease or out of balance. We will see what there mech's think is best way to minimize..
Old 01-26-2014, 03:45 PM
BigMix's Avatar
I definitely get the tire sliding. Had no idea it could be related to the ABS or AdvancTrac. I just assumed it had more to do with the stiffness of the rear suspension when unloaded in combination with the factory 245/75/17s at 80psi. I never hear a noise from the ABS or tires squealing. It just seems to "float" to the opposite direction of the turn.
Old 01-27-2014, 03:53 PM
Just when I checked off one issue another pops up. The dreaded injector tap. Heard it today under cold start..Boy that was loud..I went and threw in some Lucas Upper Cylinder lubricant and drove off. I never heard again even when got home. Truck engine was nice and warm. I will see how it goes in morning..Suppose to be in 20's. If it starts up again it will be at dealer. I am not going to listen to that for the next 10 years. Cant Ford build a truck anymore..Between this and the vibration..really wondering if Ford is going back to there ways of the 80's..Maybe they should took some Govt money if it meant getting better parts in these trucks...
Old 01-28-2014, 08:20 AM
JohnnyThunder JohnnyThunder is offline
JohnnyThunder is starting off with a positive reputation.
I get the fan noise every once in a while but have no idea what you are refering to as to the vibration as mine is smooth as silk. Also never have got the abs kicking in and I drive on some pretty rough roads. Are you sure the engine rattle you heard was injectors? Mine makes a racket every once in a while and I was told it is the cam phasars, although it happens more often with a warm engine than cold. The first time that happened it scared the crap out of me I was right in front of the dealers shop that time.
Does it make sense to buy a SD? SCbarber 2017 Super Duty 51 12-19-2016 10:12 PM
Second guessing F-150 plan. Now leaning toward SD. DIRTWHEELS 2017 Super Duty 20 12-13-2016 05:34 PM
Is the 6.2L in the 250 SD the same as a Raptor? JimRay Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection 7 04-26-2014 06:26 PM
2014 SD w/6.2L..reviews?? Go Big or Go Home! 6.2L V8 61 02-26-2014 02:34 PM
Back where I belong! 2014 SD Go Big or Go Home! 1999 to 2016 Super Duty 7 12-30-2013 11:06 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
