Query on exhaust - Ford Truck Enthusiasts Forums
Australia Chapter Join Chapter , Leader: ChunderDownUnder
Query on exhaust
Old 01-25-2014, 12:23 AM
Patchy 73's Avatar
Patchy 73 Patchy 73 is offline
Patchy 73 has a very good reputation on FTE.Patchy 73 has a very good reputation on FTE.Patchy 73 has a very good reputation on FTE.
Query on exhaust
Hi All,
There is a truck up my way that sounds really throaty. I bumped into him today and asked him what exhaust system he was running, he said he's not, he has just removed the muffler
Is this good or bad for the motor, I'm not technically minded so I'll just put the question out there
Cheers,
Patchy
Old 01-25-2014, 03:10 AM
SSSimon SSSimon is offline
SSSimon has a great reputation on FTE.SSSimon has a great reputation on FTE.SSSimon has a great reputation on FTE.SSSimon has a great reputation on FTE.
I tried it but it did my head in - too loud! I'm running a 4" turbo back system with 2 'Hurricane' mufflers now.
If you have the Ford Australia turbo downpipe fitted you could delete the muffler. Any good exhaust shop could do it - they just make up a 3.5 inch diameter 'muffler delete' pipe.
No adverse knock-on affects on the engine/turbo from this that I'm aware of - in fact it would be an improvement as your EGT should drop with the removal a slight restriction. The problem is that the main restriction is the FA 2.5 inch downpipe which sits between the 3.5in turbo outlet and the stock 3.5in exhaust!
Old 01-27-2014, 04:59 PM
BigF350 BigF350 is offline
BigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputation
Diesels don't run "closed loop" like petrol engines, so you can do whatever you like to the exhaust as soon as it leaves the engine and it won't know any difference (unless its a new diesel with DPF). As Simon mentioned, the more flow/larger the exhaust after the turbo the better.
On my 7.3, I had a 4" dump/straight pipe from the turbine housing that exited just behind the cab (before the rear wheels). It sounded mean, and I am pretty sure there was permanent hearing damage caused to anyone following me in a tunnel when I downshifted. I didn't find the noise annoying at normal cruise, but as soon as it got under load it was too loud for continuous use - I didn't do any towing, but long uphill stretches were a bit of a pain.
If you do any towing, I would definitely suggest a muffler - but even running it behind the rear wheels would help a lot.
Old 01-28-2014, 03:47 AM
Brad from Oz's Avatar
Brad from Oz Brad from Oz is offline
Brad from Oz has a good reputation on FTE.Brad from Oz has a good reputation on FTE.Brad from Oz has a good reputation on FTE.
So Ford Aust put a step down restrictor pipe straight off the back of the exhaust housing?
Wow - let me guess, these utes are slow to spool up and they suffer high EGT's, possibly even cracked exhaust housings or tip rubbed, over temped exhaust wheels?
The goal is to have a step up diameter pipe straight off the housing, this stops the exhaust gasses spinning and gets them flowing properly. So that 4 inch dump sounds good
Old 01-28-2014, 04:03 AM
Patchy 73's Avatar
Might have a play with this I got twins out the back of mine so it should not be to noisy from the cab
Cheers,
Patchy
Old 01-28-2014, 04:58 AM
Patchy, check your turbo down pipe. If it is the crap FA 2.5" one the best $wise way to get an improvement in all aspects would be to swap the FA pipe out - which is easy if you cut it out, and replace that section with a 3.5" DP to hook-up to your existing system.
Old 01-30-2014, 12:26 AM
Patchy 73's Avatar
I got a 3"DP with this tag
Now you got me a little confused, Lot of mention of the FA DP,
so where does the Brazil one fit in the grand scheme of things
Still learning things about my truck
Cheers,
Patchy
Old 01-30-2014, 05:13 AM
Looks like a picture of a tail pipe there, looking up from the ground, yep 100% pure Brazilian no doubt about it - you can tell cause there's no hair !
You have to work your way forward and check where the exhaust goes up past the footwell on the way to the turbo, that's where the Down Pipe lives. That is where you'll find the FA DP - a lot of welded pieces choking it down to 2.5"
So you have a twin system hanging off the back of your stock Brazilian tailpipe?
This picture shows the FA DP above the stock Brazilian tailpipe - the little strangle box is clearly visible.
Old 01-30-2014, 05:20 AM
Here is a picture of the MBRP 4" turbo back exhaust I bought of Clay and shipped over USAtoAUS. The pipe on the lower left is the muffler delete pipe (I wish I bought the muffler now).
The 4" DP ended up being very hard to fit and had to be dented into submission - so much so that I think I may have had a better result getting a 3.5" DP into a 4" exhaust.
Old 01-30-2014, 08:36 AM
Patchy 73's Avatar
The shot was taken just before it up sweeps
to the turbo ,directly under the fire wall
DP 3.5 will be the way I go, thanks for the info
Cheers,
Patchy
Old 01-31-2014, 01:55 PM
A 3.5" DP will be the way to go. My firewall was "massaged" to fit the 4" DP on my 7.3
My current 6.7 (which is a quieter engine than the 7.3 anyway) has a 4" straight pipe, and sounds good (not too loud). It exits after the rear wheel.
Old 01-31-2014, 09:24 PM
ChunderDownUnder's Avatar
ChunderDownUnder ChunderDownUnder is offline
ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.
a bit OT but how the 6.7L Adrian ??? very interested from someone who has Aussie experience. Maybe a fresh thread. Oh and we like pics
Old 01-31-2014, 09:36 PM
Diesel Submariner's Avatar
Diesel Submariner Diesel Submariner is offline
Diesel Submariner is gaining momentum as a positive member of FTE.
MODED EXH
G'day Patchy,
There's a good discussion on this subject on the tread "MODED EXHAUST" on page 5 of this Aussie Chapter forum.
Worth a read through as most of us have been through this saga.
Cheers,
Reg
Old 02-03-2014, 12:08 PM
Quote:
I think I can oblige
Old 02-03-2014, 04:49 PM
Patchy 73's Avatar
Quote:
Originally Posted by Diesel Submariner View Post
G'day Patchy,
Cheers,
Reg
Thanks for that Reg, Whish I found it earlier a good read
The only hassel I seem to going to have is finding someone in Cairns willing to do the fit
Cheers,
Patchy
Am i wasting my time Patchy 73 Australia Chapter 11 11-22-2015 04:23 AM
AU Dump Pipe Patchy 73 Australia Chapter 1 10-03-2015 10:50 PM
Front Hub Patchy 73 Australia Chapter 9 05-03-2015 07:29 AM
Header Tank Cap Patchy 73 Australia Chapter 2 01-15-2015 04:56 PM
Has any one had a water pump failure like this Patchy 73 1999 to 2016 Super Duty 3 07-18-2014 05:30 PM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
