Australia Chapter Join Chapter , Leader: ChunderDownUnder
WW/G2
Old 01-03-2013, 12:37 AM
Loaf4000's Avatar
Loaf4000
Loaf4000 is offline
WW/G2
Has any one got the new WW/G2 yet
If so how good is it
Cheers
Rod
Old 01-03-2013, 01:57 AM
ChunderDownUnder's Avatar
ChunderDownUnder
ChunderDownUnder is offline
G'day Rod
I'll steer you to this thread bro. The links have all the info. Very impressive results on the stock turbo. Not so much on the 38R. Have you spoken to Jody yet ??
Old 01-03-2013, 02:46 AM
Loaf4000's Avatar
Loaf4000
Loaf4000 is offline
No not yet
I thort the new WW may help with
High egt
Black smoke
Cheers
Rod
Still on the **** at foster
2 days to go
Old 01-04-2013, 08:11 PM
ChunderDownUnder
No worries Rod. I would speak to Jody before spending any more money m8.
Bryan (Nkelly) is going through the same scenario as you and believes its in the tunes. Enjoy the break m8.
Old 02-08-2013, 03:42 AM
SSSimon's Avatar
SSSimon
SSSimon is offline
Got my 45psi boost gauge today. I'll install it over the w/e and get some measurements of the max boost before the change over to the G2WW.
The gauge is the stepper motor type with adjustable alarm setting and max value recall.
I'll set the alarm at 40 psi - I wont expect to see that with the stock wheel which seems to just top out the current 30psi gauge.
FLIPPING FLEA-BAY, ordered a 52 mm guage, they sent me the 60mm one then went on holiday for 2 weeks.
This is going to take longer than I expected...
Old 03-23-2013, 01:43 AM
Nkelly's Avatar
Nkelly
Nkelly is offline
Farkall User
Originally Posted by Loaf4000
No not yet
High egt
Black smoke
Cheers
Rod
2 days to go
Gday wodney have you done anything inregards to the WW yet,im going to bang this WWG2 in, might be the go for my excess fuel,gotta do me up pipes aswell
Old 03-24-2013, 02:16 AM
SSSimon's Avatar
SSSimon
SSSimon is offline
Wod's still running the FA stock down-pipe inin't he?
Me thinks the FA downpipe is the 'root' of all EGT and other tuning woes on the Ozzy F250s.
I had close to a 400C drop in EGT, under load going from a FA stock DP to a 4" DP. I think Reg, after initally thinking of retaining the stock DP, was inspired to get a 3.5" DP made and also got a huge improvement. Rod aptly described the FA DP something like an 'abortion of engineering'. Pretty much sums it up.
Old 08-26-2013, 05:40 AM
SSSimon's Avatar
SSSimon
SSSimon is offline
WWG2 fitted over the w/e - yay!
Finally got some wrenching time.
I removed the turbo and pulled off the compressor housing:
https://plus.google.com/photos/10776...13830402976812
What I found was a blackened stock compressor wheel and a fair bit of black lining the IC pipes and boots. Boo!
I've ordered the GTP38 turbo rebuild kit from Clay.
While I wait I figured I'd fit the WWG2 wheel and put it back together for a bit of a test spin.
Running:
stock sticks & HPOP, 6637 air filter, EBPV delete turbo outlet, AIH delete, 4" turbo back system, Superchips performance tune, Overboost Code Regulator and:
1) Stock compressor wheel: 27psi boost;
2) WWG2 compressor wheel: 30psi boost (gauge maxed out).
I will not use the truck now until I have completed the turbo seals rebuild.
After which I will put it to the real test to see if the turbo surge encountered with the stock wheel has been cured with the WWG2.
Old 02-15-2014, 03:25 AM
SSSimon's Avatar
SSSimon
SSSimon is offline
WW2 is surge free under full towing load at WOT!
Success!
chukar
03-20-2016 02:10 AM
fabieber
12-20-2015 12:51 AM
xaviar
09-01-2015 09:24 PM
Schuyles
04-30-2013 10:12 AM
cathyburns
1999 to 2016 Super Duty
01-13-2009 03:44 PM
Quick Reply: WW/G2
