Front Spring Perch Bushing - Ford Truck Enthusiasts Forums
Old 01-25-2014, 12:22 AM
Steve's Avatar
Steve Steve is offline
Steve is gaining momentum as a positive member of FTE.Steve is gaining momentum as a positive member of FTE.
When changing the front, perch/frame mounted spring bushing, do guys usually press/drive them out and then the new ones back in with the perch in the truck?
Or do you have to grind the rivet heads and replace the perch? Looks to me like it could be done in the frame.
Old 01-25-2014, 12:58 AM
Dano78's Avatar
Dano78 Dano78 is offline
Dano78 has a good reputation on FTE.Dano78 has a good reputation on FTE.Dano78 has a good reputation on FTE.
I did mine in-frame Steve. If using Mid Fifty's Tool, you're gonna beat the hell out of it. Its more designed for just press use. But certainly can be done in-frame. And I haven't forgot about the front axle... just got tied up today. Sorry.
Old 01-25-2014, 01:06 AM
Steve's Avatar
Yeah I figured. I'm going to a big swap meet tomorrow, so maybe I'll see one. As for the bushing, I might cobble together a pressing tool and see how that looks.
Old 01-25-2014, 06:54 AM
aussiecowboy aussiecowboy is offline
aussiecowboy is gaining momentum as a positive member of FTE.aussiecowboy is gaining momentum as a positive member of FTE.
Definitely in frame, can be done no problem.
Old 01-25-2014, 10:37 AM
raytasch's Avatar
raytasch raytasch is offline
Old guy with old toys
raytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant future
Threaded rod with nuts, some flat washers, a piece of pipe works fine, in and out. Grind washer OD to fit.
1986 Sway Bar & Mounts DDDDDMorgan 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 11 10-04-2016 02:57 PM
Coil Spring Perch HELP PLEASE Wesley Fox 1973 - 1979 F-100 & Larger F-Series Trucks 1 07-11-2016 01:11 PM
78 F 250 REAR spring perch center to center dimension wyazel1 1973 - 1979 F-100 & Larger F-Series Trucks 2 05-18-2016 05:06 PM
rear leaf spring install 93F150&69Stang 1987 - 1996 F150 & Larger F-Series Trucks 9 11-28-2015 02:31 PM
E350 coil spring perch width? rebar13 1968-2013 Full Size Vans 1 09-18-2015 05:19 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
