1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
FUEL PUMP RELAY
Old 01-24-2014, 08:53 PM
norcalpaw's Avatar
norcalpaw
norcalpaw is offline
Angry FUEL PUMP RELAY
2004 F-350, V10, Auto, 82,000 miles.
At 80,000 I had to replace the fuel pump, now the dealer tells me my fuel pump relay is bad and is NOT replaceable. They say the whole control box needs to be replaced at the tune of $700.00!!! I can't believe the relay can't just be replaced with a new one since it is listed in the Ford parts book as a separate item. HELP!!
Old 01-24-2014, 09:26 PM
Bobbykjl's Avatar
Bobbykjl
Bobbykjl is offline
A model 2000 V10 schematic shows it as a separate relay...but who knows if it's the same as a 2004. I also came across an old post that talked about the fuel pump relay being right next to the AC relay just above the steering column on the firewall.
Old 01-24-2014, 09:51 PM
Bigpipes 35's Avatar
Bigpipes 35
Bigpipes 35 is offline
I think with 2003 and later gas motors the fuel pump relay is part of the PCM and not replaceable ...
Old 01-25-2014, 03:54 AM
Yahiko's Avatar
Yahiko
Yahiko is offline
It's the same with the 6.0L
That relay is buried in the CJB. Along with a few others.
I think you might be able to bypass it and install one
outside the CJB. But doing that may have unknown risks.
One of them being if you were in an accident and something
were to happen would the insurance Co throw you to the sheep (er wolves).
I have seen CJBs for sale on Ebay for a lot less than $700.
Also they are not that hard to replace and you could pick up one
from AutoNation Ford White Bear Lake Parts (previously Tousley Ford Parts)
and install it your self.
Sean
Old 07-29-2014, 06:14 PM
ed dennison's Avatar
ed dennison
ed dennison is offline
no fuel pressure
2003 , f350 , fx4 , lariat, v10 , Crew cab, SRW. Have a no start condition. checked fuse in main fuse panel, checked inertia switch to see if needed reset. replaced fuel pump. Still no start. Went to dealership to find out where fuel pump relay is located. they did not know or care to share. Napa says thay have relay for $ 20. they don't know where to plug it in . Any ideas out there? Any help is appreciated.
Old 07-29-2014, 08:57 PM
Yahiko's Avatar
Yahiko
Yahiko is offline
Again it's in the CJB.
Sean
Old 07-29-2014, 09:22 PM
cliff_mennenger's Avatar
cliff_mennenger
cliff_mennenger is offline
Looks like it resides behind the radio.
Take care.
Old 07-29-2014, 10:30 PM
ed dennison
Thanks so much for the responses . Will put info to work tomorrow.
Old 07-30-2014, 07:49 AM
projectSHO89's Avatar
projectSHO89
projectSHO89 is online now
Not on an '03 Super Duty V10. It's integrated into the CJB and is not an individually serviceable part as Yahiko already said twice. It was moved starting around the 2002 MY for the pckups.
Old 07-30-2014, 06:39 PM
ed dennison
fuel pump relay
So The fix for a suspected faulty fuel pump relay is to replace the main fuse panel down by the drivers left knee?
2003 f350, CC, 4x4, v10 lariat, auto
Old 07-30-2014, 08:42 PM
projectSHO89
That would be the fix for a known faulty fuel pump relay unless you can do a component level repair or a relay bypass.
Old 07-30-2014, 09:27 PM
Yahiko's Avatar
Yahiko
Yahiko is offline
I should have some time later tonight to look for the diagram for the CJB so
you can test that relay to make sure that is the problem.
In the meantime here is a PDF on pinpoint testing and a few others things.
Sean
Old 07-31-2014, 11:44 PM
ed dennison
Fuel Pump relay
I greatly appreciate the input and depth of knowledge on this site. To update you on my progress so far: Pulled fuse #40 (fuel pump) in the CJB, turned key on , read 12v on input side, checked and replaced fuse. disconnected 2 wire harness at inertia switch, turned key on , read 8.3 volts on DG/Y input to inertia switch. Ran wire from battery thru 15 amp house switch to output from inertia switch. Started truck drove to town and back. I don't really understand what could cause the voltage drop between the fuse and the inertia switch. Is the fuel pump relay the only device between the fuse and the inertia switch.
2003 f350 superduty, CC, fx4 lariat, v10, auto
CJB 3C3T-14A067-BG
Old 07-31-2014, 11:51 PM
Yahiko's Avatar
Yahiko
Yahiko is offline
The 8.3V that you came up with. Was that between the relay output and the
inertia switch? If so that is a large drop in the voltage.
I'll get the 03 diagram and post in an hr or so.
Sean
Old 08-01-2014, 12:08 AM
ed dennison
Fuel Pump relay
Thanks Yahiko, That voltage drop was between the fuse and the inertia switch. tomorrow i will pull the fuse panel and find and check the output of the relay. Didn't get much time to work on it today. i will check for your posts 1st thing in the morning. thanks
2003 f350 Superduty
Quick Reply: FUEL PUMP RELAY
