Help on Mercury rear axle - Ford Truck Enthusiasts Forums
Old 01-24-2014, 09:45 PM
Bridgeford's Avatar
Bridgeford Bridgeford is offline
Bridgeford has a very good reputation on FTE.Bridgeford has a very good reputation on FTE.Bridgeford has a very good reputation on FTE.
Our 49 M68 has had the rear axle changed by the previous owner, so that makes it easier to get rid of the widowmaker rims. We are going to redo the brakes on the truck so I am sourcing wheel cylinders. I, however, have been unable to identify what vehicle the rear axle came from, so I can't find a part match. The axle has a round 10 bolt rear inspection cover and has an 8x6.5 bolt pattern on the wheels. I have searched some differential identification charts on the internet and have searched some FTE threads but can't find the info I need. I was hoping someone on here might be able to recognize it. I was hoping it was a Dana 60 but the charts say no. It has rear shock mounts welded on it so I thought it must be from the 50's or 60's. I have searched RockAuto and Napa sights for the wheel cylinders from 3/4 tons and one tons but none look like the cylinders from this axle. They are 1 3/8 inch bore and have R-6 and 6460072 stamped on them. The only stamp on the axle is the number 3682726. Maybe it is not even a ford axle. Here is a couple of pictures. Any help would be appreciated.
Old 01-24-2014, 10:25 PM
51dueller's Avatar
51dueller 51dueller is offline
51dueller has a great reputation on FTE.51dueller has a great reputation on FTE.51dueller has a great reputation on FTE.51dueller has a great reputation on FTE.
That looks like an Eaton HO72 out of a 1947-72 GM/Chev 3/4 or 1 ton.
Old 01-24-2014, 11:04 PM
Bridgeford's Avatar
Thanks Nathan, that was it. A 1951 Chev truck takes the same wheel cylinder as what we have here. I now can order parts. Thanks again.
83 F-100 BAYOU-PROJECT joshs598 Projects 39 01-19-2017 09:13 PM
1977 F150 4x4 Longbed Regular Cab bigredtruck Vehicles for Sale 0 06-29-2016 10:46 AM
The clutch that wouldn't die bigredtruck Cooling, Heating, Ventilation & A/C 0 05-10-2016 10:18 PM
'07 Trailblazer SS swap in '51 Ford F1 giobizio 1948 - 1956 F1, F100 & Larger F-Series Trucks 16 04-22-2016 02:42 PM
Help identifying mystery insulation part trpltongue 2007 - 2014 Expedition & Navigator 8 01-15-2014 11:49 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
