48-52 Lower Door Seal and Retainer ??????
I need the advice of the 48-52 door molding / seal experts.
I purchased the lower door seals from a well known vendor and tried to install them in my original rust free lower seal retainers. The new seals just will not go into the original retainers, too thick, too wide, length is OK. High temperatures, low temperatures, lubrication, they just will not fit. So, I purchased new metal seal retainers and the rubber seals slide right into the new retainer, just like they were made to fit. The new retainer is wider than the original.
So, can someone tell, explain to this old boy how to fit the new seals into the original retainers? Or, must I do what I hate to think of doing, drill the welds and remove those nice original rust free seal retainers?
I learned many years ago that when I was doing something and found it difficult, perhaps I was missing something, doing it the wrong way.
So, how about it FTE Monkey Face and Manure Spreader experts, what am I doing wrong. Help this old boy out Certainly someone has been here and done this.
They are just a #$%^&* to get in. I spent at least an hour a side poking it in with a small screwdriver, one blade-width at a time. It really helps to thoroughly clean the track first, which I'm sure you did. I don't doubt they are just not "as original" by a few thousandths, and no way on earth would they slide in on mine. To add insult to injury, they don't seal against the door when closed....
You could try bending up the lips at one end, soaping the rubber, and try feeding it in. Good luck!
Well, after much dis cussin with Blue and her reluctance to have new rubbers fit, I realized they were not going in as they were. Perhaps with a way to compress the part that fit into the retainer but I was not going to build a special tool. After measuring the seal, measuring the retainer, I trimmed about 3/32" off the edge of the seal. I was then able to work the seal into the retainer after the modification. I'll do the other side tomorrow, supposed to be a bit warmer. And, yes, I scratched the paint.
Thanks for the replies, suggestions and comments.
dancraig
12-27-2018 03:02 PM
1950FordF1
08-09-2015 07:50 AM
old broke prospector
07-02-2013 10:50 PM
