48-52 Lower Door Seal and Retainer ?????? - Ford Truck Enthusiasts Forums
Old 01-24-2014, 01:57 PM
raytasch's Avatar
raytasch raytasch is online now
Old guy with old toys
raytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant future
I need the advice of the 48-52 door molding / seal experts.
I purchased the lower door seals from a well known vendor and tried to install them in my original rust free lower seal retainers. The new seals just will not go into the original retainers, too thick, too wide, length is OK. High temperatures, low temperatures, lubrication, they just will not fit. So, I purchased new metal seal retainers and the rubber seals slide right into the new retainer, just like they were made to fit. The new retainer is wider than the original.
So, can someone tell, explain to this old boy how to fit the new seals into the original retainers? Or, must I do what I hate to think of doing, drill the welds and remove those nice original rust free seal retainers?
I learned many years ago that when I was doing something and found it difficult, perhaps I was missing something, doing it the wrong way.
So, how about it FTE Monkey Face and Manure Spreader experts, what am I doing wrong. Help this old boy out Certainly someone has been here and done this.
Old 01-24-2014, 02:04 PM
FortyNiner's Avatar
FortyNiner FortyNiner is online now
FortyNiner is a splendid one to beholdFortyNiner is a splendid one to beholdFortyNiner is a splendid one to beholdFortyNiner is a splendid one to beholdFortyNiner is a splendid one to beholdFortyNiner is a splendid one to beholdFortyNiner is a splendid one to behold
Don't know what to tell you Ray. I replaced mine last fall on the '49 and didn't have any fit issues going into the original retainers. The one's in installed were relabeled DC product.
Gotta wonder if the item wasn't mis-marked and simply the wrong size.
DW
Old 01-24-2014, 02:31 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is online now
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
They are just a #$%^&* to get in. I spent at least an hour a side poking it in with a small screwdriver, one blade-width at a time. It really helps to thoroughly clean the track first, which I'm sure you did. I don't doubt they are just not "as original" by a few thousandths, and no way on earth would they slide in on mine. To add insult to injury, they don't seal against the door when closed....
You could try bending up the lips at one end, soaping the rubber, and try feeding it in. Good luck!
raytasch's Avatar
DW
Thanks. My seals are DC products, also. The rest of the stuff for the door looks and fits like it should.
And, I have removed all the paint from the original retainer.
Old 01-24-2014, 04:38 PM
dmack91's Avatar
dmack91 dmack91 is offline
dmack91 has a great reputation on FTE.dmack91 has a great reputation on FTE.dmack91 has a great reputation on FTE.dmack91 has a great reputation on FTE.
I got mine through Classic Haulers, but had the exact same issues as Ross, as in identical on all accounts.
Old 01-24-2014, 06:11 PM
raytasch's Avatar
Well, after much dis cussin with Blue and her reluctance to have new rubbers fit, I realized they were not going in as they were. Perhaps with a way to compress the part that fit into the retainer but I was not going to build a special tool. After measuring the seal, measuring the retainer, I trimmed about 3/32" off the edge of the seal. I was then able to work the seal into the retainer after the modification. I'll do the other side tomorrow, supposed to be a bit warmer. And, yes, I scratched the paint.
Thanks for the replies, suggestions and comments.
NP435 Rebuild ronspolv 1973 - 1979 F-100 & Larger F-Series Trucks 0 03-13-2015 05:09 PM
51 Ford COE C6 F6 Windshield Seals TCFOMOCO 1948 - 1956 F1, F100 & Larger F-Series Trucks 10 10-07-2014 09:53 AM
F-1 doors 56panelford 1948 - 1956 F1, F100 & Larger F-Series Trucks 13 10-05-2014 09:47 AM
5.4 Rear Crank Seal/Oil Slinger ExpyDude99 Modular V8 (4.6L, 5.4L) 4 07-15-2014 09:31 PM
My lower radiator hoses will not hook up. THE BLUE BEAST 6.4L Power Stroke Diesel 1 02-18-2014 09:56 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
