51 ford f2 rear axle nut
Old 01-22-2014, 03:20 PM
redneckfordman1's Avatar
redneckfordman1
redneckfordman1 is offline
hey guys been working on my brothers truck a little lately trying to get it moving again. i found the right rear brake lockedup due to a bad seal allowing the grease to contaminate the shoes. anyways im tryin to get it all fixed again but im having troubles finding a socket for the main bearing nut. any help would be appreciated
Old 01-22-2014, 03:36 PM
raytasch's Avatar
raytasch
raytasch is online now
Believe Nothing
Wrenches are available. Shown is the correct KD wrench for the Dana 60, 2 9/16". Measure the nut on your axle. Most good auto parts stores will have the socket. Some stores may even have loaners. I bought mine at NAPA.
Old 01-22-2014, 03:52 PM
redneckfordman1
ive already tried 2 1/4 and 2 3/8 12 point sockets one was too big other too small
Old 01-22-2014, 04:38 PM
raytasch's Avatar
raytasch
Believe Nothing
Don't think a regular socket is going to work. Look at the nuts,
Old 01-22-2014, 04:46 PM
redneckfordman1
Should still give a fair idea of size tho I'd imagine
Old 01-22-2014, 04:48 PM
jmadsen's Avatar
jmadsen
jmadsen is offline
I always just use a hammer and chisel to get it loose! of course I like to do things the hard way...
Old 01-22-2014, 05:02 PM
redneckfordman1
That's what its lookin like I'm gonna do pretty soon. These are normal threads not reverse correct?
Old 01-22-2014, 05:09 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is online now
How are you going to torque it when re-assembling it with a hammer and chisel?!
Old 01-22-2014, 05:12 PM
redneckfordman1
I won't but if I can at least get it off then illI'll be able to figure out what parts iI need/find correct ones and find a correct socket to put it back together
Old 01-22-2014, 05:19 PM
raytasch's Avatar
raytasch
Believe Nothing
Look at the KD part number on the special wrench. Sorry it is upside down. Read the very fine print on the arrows of my picture. This is what happens when the nuts are removed with a hammer and punch.
Edit: disclaimer on the size of the axle nuts on your truck.
Old 01-22-2014, 05:31 PM
ALBUQ F-1's Avatar
ALBUQ F-1
'51 F-2 is a different size, 2-3/8" but as Ray says, a regular socket probably won't fit. You need one of the tube wrenches like shown.
Old 01-23-2014, 11:59 AM
arctic y block's Avatar
arctic y block
arctic y block is offline
Just go into like Napa and ask for a spindle nut socket. Explain to the
counter kid what it is. Cost is only a few bucks. I also use a chisel and BFH.
most of the time as they are in the tool box and I have to look hard for my spindle
socket.
Old 01-24-2014, 08:07 PM
1952henry's Avatar
1952henry
1952henry is offline
An original Ford issue (Moore Forging) F3 wheel nut wrench and handle (doubles as tire iron).
79str8six
10-14-2020 12:45 PM
FORDF250HDXLT
25
11-19-2014 11:48 AM
78ford351m
35
10-18-2010 01:12 PM
BACRAKR
05-23-2009 12:33 PM
ChucksTruck
09-23-2001 09:09 PM
Quick Reply: 51 ford f2 rear axle nut
