Early 223 rocker arm
01-24-2014, 09:28 AM
In desperate need of early rocker arm assembly with the studs that protrude for early valve cover Thanks Dude
01-24-2014, 01:20 PM
I should have one from a 215. Is that early enough?
01-24-2014, 01:42 PM
should be if it's the same for the 223 ")")
01-24-2014, 01:58 PM
1952/53 215, 1954/59 223: Valve cover retained to the head with two studs that poke thru the cover.
1960/64 223 uses a different head, valve cover retained by eight bolts. One at the front & rear, three on each side.
01-24-2014, 07:53 PM
I think I might have some too...
01-24-2014, 08:29 PM
let me know when you can Are you snowed in?
01-24-2014, 08:58 PM
on
223 parts have lots of them
I have one from 54 223 ci
01-24-2014, 09:08 PM
Yup. Got one. Last one in my stock.
Uploading a pic soon.
01-25-2014, 12:15 AM
Here's what I have. PM or email me. You have credit with me for the oil pick up.
01-25-2014, 02:23 PM
01-25-2014, 05:39 PM
I have a new coming so I am all set with the rocker arm set up Thanx guys
mechanic58
11-06-2014 03:18 PM
Bobby Maguire
02-04-2014 04:12 PM
AbandonedBronco
03-02-2011 10:34 AM
sandhillmike
08-26-2007 10:03 PM
shaftmountrocker
05-18-2005 07:52 AM
