Early 223 rocker arm
Old 01-24-2014, 09:28 AM
1948 F1dude's Avatar
1948 F1dude
1948 F1dude is offline
In desperate need of early rocker arm assembly with the studs that protrude for early valve cover Thanks Dude
Old 01-24-2014, 01:20 PM
51PanelMan's Avatar
51PanelMan
51PanelMan is offline
I should have one from a 215. Is that early enough?
Old 01-24-2014, 01:42 PM
1948 F1dude
should be if it's the same for the 223 ")")
Old 01-24-2014, 01:58 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
1952/53 215, 1954/59 223: Valve cover retained to the head with two studs that poke thru the cover.
1960/64 223 uses a different head, valve cover retained by eight bolts. One at the front & rear, three on each side.
Old 01-24-2014, 07:53 PM
tinman52's Avatar
tinman52
tinman52 is offline
Welder User
I think I might have some too...
Old 01-24-2014, 08:29 PM
1948 F1dude
let me know when you can Are you snowed in?
Old 01-24-2014, 08:58 PM
49 ford fire truck's Avatar
49 ford fire truck
49 ford fire truck is offline
223 parts have lots of them
I have one from 54 223 ci
Old 01-24-2014, 09:08 PM
51PanelMan's Avatar
51PanelMan
Yup. Got one. Last one in my stock.
Uploading a pic soon.
Old 01-25-2014, 12:15 AM
51PanelMan's Avatar
51PanelMan
Here's what I have. PM or email me. You have credit with me for the oil pick up.
Old 01-25-2014, 02:23 PM
1948 F1dude
51PanelMan sent PM
Old 01-25-2014, 05:39 PM
1948 F1dude
I have a new coming so I am all set with the rocker arm set up Thanx guys
mechanic58
11-06-2014 03:18 PM
Bobby Maguire
02-04-2014 04:12 PM
AbandonedBronco
03-02-2011 10:34 AM
sandhillmike
08-26-2007 10:03 PM
shaftmountrocker
05-18-2005 07:52 AM
Quick Reply: Early 223 rocker arm
