milky white stuff
01-24-2014, 08:53 AM
on
milky white stuff
Pulled out my oil dipstick today and seen a little milky stuff on the edges, ive seen it on the cap before but never on the dipstick. Could it be from condensation or to much fuel? I have not over heated this engine. 85 300 inline 6.
01-24-2014, 09:03 AM
on
Most likely just condensation, common for this type of weather if the engine doesn't get hot and run for a good 30 minutes or better. Run around for a while, then shut it off and check.
01-24-2014, 09:12 AM
on
Thanks. Thats what i'm hoping.
01-24-2014, 09:47 AM
What thermostat are you running? All of these trucks are built for 192/195 stats, and if you go with less you may never get the oil hot enough in winter to boil off the condensation.
01-24-2014, 12:30 PM
Also check your PVC system for functionality. Plugged up PVC will not pull out the condensates from the crankcase.
01-24-2014, 06:38 PM
Most likely from condensation but a blown or broken head gasket can cause it as well.
JRitt
12-29-2014 07:45 PM
mattparham1
34
01-07-2014 10:47 PM
RyansFord10
02-06-2012 07:49 PM
now_what
01-10-2009 01:45 PM
dustof45
1947 and Older Ford Trucks
03-18-2004 11:41 AM
