Removing front fenders
One of the reasons I think the bolts came out so easily was a product an old friend introduced me to called "Kroil". You guys may be familiar with it but I wasn't. Before using some of my friends' Kroil I was certain I would never get the nuts off the exhaust manifold where it bolts to the tail pipe. I put some of the Kroil on one night and the next night the nuts came off with the ratchet even though there is little room to get leverage.
Home made penetrating oil
The home brew of ATF and Acetone is great stuff.
I'm surprised no one has asked for pictures yet so I will. Pictures please.
It's not that heavy. I could stand between the inner fenders, grab under the air deflectors and pick it up by myself. (without the radiator or support) When I moved a friend of mine and I picked it up and shoved it into an E150 without any problem.
I pulled the front clip from my truck last weekend (I left the radiator and mount in the truck) On the 48-52 trucks the clip isn't aht heavy at all. I use a hand dolly to wheel it around. The biggest problem is the rear of the fenders wanting to flop all over the place. To move it with a dolly I put the dolly under the lower grill valance and then bungee cord a long 2x4 across the top of the dolly to support the back of the fenders. Then its no problem to wheel the thing anywhere you want to go
Bobby
Bobby
For anyone who has removed the front clip on a 53-56 pickup you are probably laughing at my bolt count.
Last night I gave an accounting of how many bolts there are and where.
Today I found 4 more on each side. Three of the four are accessed from inside the truck and one on the very bottom of the cowl is removed from outside.
Front is now completely loose and I will lift it off tomorrow.
I can confirm that it was petty easy although I had a heckuva time with the two cowl bolts that are accessed from inside the engine bay and are down by the clutch peddle.
They were easy enough to reach and wouldn't have been difficult but they were exceedingly rusty compared to the others.
When I pulled mine off, I was really lucky. They were so far gone that I was not able to save them, so I cut them off piece by piece, and cut each bolt. There was a severe amount of "body work" that was attempted by the previous owner. Needless to say, he wasn't a professional. He ruined a half way decent pair of front fenders on my '49.
So, my upload test worked. I want to post some pictures of my progress toward removing the front fenders but the size of the picture I uploaded seems a bit over the top.
Is it OK to post pictures of this size or can they somehow be reduced?
I am ready to post the pics but will wait for you guys to let me know what to do.
Thank you guys for all the help and encouragement. Looking back over my post from Saturday (after a long day) I can't believe how I spelled "peddle" (although after 2 hours removing 3 hard to reach bolts I actually thought about peddling Floyd!).
If you don't think the pictures are overbearing I will post a few from Floyd's arrival at my house up to his current condition.
#30
