Removing front fenders - Page 2 - Ford Truck Enthusiasts Forums
Old 01-25-2014, 06:55 AM
Harrier's Avatar
Harrier Harrier is online now
Harrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud of
Quote:
Originally Posted by fabieber View Post
One of the reasons I think the bolts came out so easily was a product an old friend introduced me to called "Kroil". You guys may be familiar with it but I wasn't. Before using some of my friends' Kroil I was certain I would never get the nuts off the exhaust manifold where it bolts to the tail pipe. I put some of the Kroil on one night and the next night the nuts came off with the ratchet even though there is little room to get leverage.
Here is some information on penetrating oil. This came from Bob's website.
Home made penetrating oil
The home brew of ATF and Acetone is great stuff.
I'm surprised no one has asked for pictures yet so I will. Pictures please.
Old 01-25-2014, 08:12 AM
EffieTrucker's Avatar
EffieTrucker EffieTrucker is offline
Kentucky Chapter Member
EffieTrucker is a splendid one to beholdEffieTrucker is a splendid one to beholdEffieTrucker is a splendid one to beholdEffieTrucker is a splendid one to beholdEffieTrucker is a splendid one to beholdEffieTrucker is a splendid one to beholdEffieTrucker is a splendid one to beholdEffieTrucker is a splendid one to behold
Thanks Effie,
I will be very cautious. Do you have any idea what the weight of the clip might be? The radiator will be attached unless that's a bad idea.
I don't mind the reminders about being under things
It's not that heavy. I could stand between the inner fenders, grab under the air deflectors and pick it up by myself. (without the radiator or support) When I moved a friend of mine and I picked it up and shoved it into an E150 without any problem.
Old 01-25-2014, 11:12 AM
bobbytnm's Avatar
bobbytnm bobbytnm is offline
Roast em' if you got 'em
bobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud of
I pulled the front clip from my truck last weekend (I left the radiator and mount in the truck) On the 48-52 trucks the clip isn't aht heavy at all. I use a hand dolly to wheel it around. The biggest problem is the rear of the fenders wanting to flop all over the place. To move it with a dolly I put the dolly under the lower grill valance and then bungee cord a long 2x4 across the top of the dolly to support the back of the fenders. Then its no problem to wheel the thing anywhere you want to go
Bobby
Old 01-25-2014, 11:39 AM
DougofMontana's Avatar
DougofMontana DougofMontana is offline
DougofMontana is starting off with a positive reputation.
Dang, this thread should have been here two months ago, LOL I'm stripping down my '49 F1 and pulled the fenders off and such piece by piece. Don't have a torch, so it was cut off wheel or grinder for 95% of the bolts. UGH
Old 01-25-2014, 08:15 PM
fabieber fabieber is offline
fabieber is gaining momentum as a positive member of FTE.fabieber is gaining momentum as a positive member of FTE.
For anyone who has removed the front clip on a 53-56 pickup you are probably laughing at my bolt count.
Last night I gave an accounting of how many bolts there are and where.
Today I found 4 more on each side. Three of the four are accessed from inside the truck and one on the very bottom of the cowl is removed from outside.
Front is now completely loose and I will lift it off tomorrow.
I can confirm that it was petty easy although I had a heckuva time with the two cowl bolts that are accessed from inside the engine bay and are down by the clutch peddle.
They were easy enough to reach and wouldn't have been difficult but they were exceedingly rusty compared to the others.
Old 01-26-2014, 08:26 AM
oldmerc's Avatar
oldmerc oldmerc is offline
oldmerc
oldmerc is a name known to alloldmerc is a name known to alloldmerc is a name known to alloldmerc is a name known to alloldmerc is a name known to alloldmerc is a name known to all
Yes one person can handle a front clip but it's much easier with help . Truly the easiest way to remove a nut and bolt that you don't want to save is to break it with an impact gun . And finally the absolute very best penetrating oil is the home made mix of ATF and Acetone .
Old 01-26-2014, 08:36 AM
flatheadkeith's Avatar
flatheadkeith flatheadkeith is offline
flatheadkeith is starting off with a positive reputation.
When I pulled mine off, I was really lucky. They were so far gone that I was not able to save them, so I cut them off piece by piece, and cut each bolt. There was a severe amount of "body work" that was attempted by the previous owner. Needless to say, he wasn't a professional. He ruined a half way decent pair of front fenders on my '49.
Old 01-26-2014, 10:21 PM
Test of my picture upload capabilities
Old 01-26-2014, 10:25 PM
So, my upload test worked. I want to post some pictures of my progress toward removing the front fenders but the size of the picture I uploaded seems a bit over the top.
Is it OK to post pictures of this size or can they somehow be reduced?
I am ready to post the pics but will wait for you guys to let me know what to do.
Old 01-26-2014, 11:14 PM
Looks like it's a good size to me. But it could be my settings.
Nice looking truck.
Old 01-27-2014, 09:53 PM
Thank you guys for all the help and encouragement. Looking back over my post from Saturday (after a long day) I can't believe how I spelled "peddle" (although after 2 hours removing 3 hard to reach bolts I actually thought about peddling Floyd!).
If you don't think the pictures are overbearing I will post a few from Floyd's arrival at my house up to his current condition.
Old 01-27-2014, 10:11 PM
I just attempted to load some more pictures and did but I have no idea where they went.
Will someone help me on how to get them sent to this thread? I did get the one to post but not sure how I did it.
Fred
  #28
Old 01-28-2014, 08:09 AM
1950FordF1's Avatar
1950FordF1 1950FordF1 is offline
1950FordF1 is gaining momentum as a positive member of FTE.
I bought a grill at the Turlock swap meet this weekend. I wondered why anyone would torch the grill off.....now I know.
Good tip guys, I would not have known and fought this for days as other obviously have.
  #29
Old 01-28-2014, 08:37 AM
I just attempted to load some more pictures and did but I have no idea where they went. Will someone help me on how to get them sent to this thread? I did get the one to post but not sure how I did it. Fred
If your pictures are too big the system will reject them. It doesn't tell you it did, they just don't show up.
  #30
Old 01-28-2014, 09:44 PM
Thank you Effie. The picture that posted was shot with a camera. The ones I tried to load were shot wit my phone.
Is it difficult to reduce their size?
Removing driver front fender? SuperDuty93 1973 - 1979 F-100 & Larger F-Series Trucks 20 03-29-2016 05:27 PM
front clip removal jpeckham 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 12 09-19-2012 12:23 PM
removing the front clip jbarefoot 1973 - 1979 F-100 & Larger F-Series Trucks 9 10-26-2011 01:01 PM
Front clip removal. 88CougarCoupe 1987 - 1996 F150 & Larger F-Series Trucks 3 05-20-2008 02:36 AM
Front clip removable in one piece? ralf 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 10 02-26-2008 08:15 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
