need help finding part on clutch arm asssembly - Ford Truck Enthusiasts Forums
Old 01-23-2014, 07:11 PM
Jprokusek Jprokusek is offline
Jprokusek is starting off with a positive reputation.
hello everyone i am new to the group and need help finding a part to my 1952 f1. I,am not sure what the part is called and cannot find it in the manual. its the part where the clutch shaft pivots and attaches to the frame looks like it could be some sort of ball socket sort of . any help would be greatly appreciated
Old 01-23-2014, 07:24 PM
jmadsen's Avatar
jmadsen jmadsen is offline
jmadsen is a name known to alljmadsen is a name known to alljmadsen is a name known to alljmadsen is a name known to alljmadsen is a name known to alljmadsen is a name known to all
I forget the part numbers but you are correct there is a ball part that bolts to the frame rail and has bronze bushings around it and the L bracket slides into it that attaches to the clutch shaft on the transmission.
Which part do you need? I've got extras of both you can have.
Old 01-23-2014, 09:21 PM
firstrider's Avatar
firstrider firstrider is offline
firstrider has a great reputation on FTE.firstrider has a great reputation on FTE.firstrider has a great reputation on FTE.firstrider has a great reputation on FTE.firstrider has a great reputation on FTE.firstrider has a great reputation on FTE.
John , glad to see you on here . These guys will help you out . Talk to you soon or will stop by to check on progress .Your in bicyle range 2 1/2 mi. round trip .
Old 01-23-2014, 10:55 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is online now
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
Sounds like you are missing 01Y-7507, equalizer shaft bracket. You likely also need the bushing that goes in the end of the shaft while you're in there.
Ford Clutch Equalizer Frame Bracket & Ball - 01Y-7507 - C&G Ford Parts
That part doesn't look exactly like what the parts manual shows.
Old 01-23-2014, 11:25 PM
jmadsen's Avatar
Hey Ross.
That link shows the part but i couldnt see if they also have the bushing that goes on it? Is anyone selling those that you know of? Maybe there was one in there but im on my dumb phone and I couldnt find one.
Thanks
Old 01-24-2014, 06:06 AM
Thank you all for responding, I need everthing that Bolts to the to frame rail. I have the shaft that goes to the transmission.
Old 01-24-2014, 06:08 AM
Quote:
That sounds great. Next time your in the neighborhood stop on in. Thanks for the information.
Old 01-24-2014, 10:55 AM
ALBUQ F-1's Avatar
postin' fool
Hey Ross.
Thanks
Yes, it's there. Inside the end of the equalizer, there is a spring, two bushing halves, and a felt seal washer.
Bushing - C2TZ-7517-A (replacements are now either brass or plastic)
Spring - 01A-7545
Felt - 01A-7539-A
Old 01-24-2014, 01:06 PM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
Originally Posted by Jprokuzek
1952 F100
No such thing as a 1952 F100. 1948/52's are F1's, F100's introduced in 1953.
If you have a 1953 F100, all the following parts are wrong...except the bushings.
01Y-7507 .. Clutch Release Equalizer Shaft Bracket / 1948/52 F1/F3 / Obsolete
GREEN SALES CO. in Cincinnati OH has 1 = 800-543-4959.
C2TZ-7517-A .. Clutch Equalizer Bar Split Bronze Bushing / 1948/64 myriad Ford Trucks / Available from Ford.
MSRP each: $3.21.
LARRY H. MILLER SUPER FORD in Salt Lake City UT has 2 = 800-950-5006.
GREEN SALES CO. has 23.
MILLER OBSOLETE PARTS in Binghamton NY has 18 = 607-722-5371.
PARTS INTERNATIONAL in Farmers Branch TX has 50 = 888-727-0418.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 53 = 800-476-9653.
01A-7539-A .. Clutch Release Equalizer Shaft Felt Washer / 1948/52 trucks / Obsolete
CARPENTER NOS OBSOLETE PARTS has 2,003.
01A-7545 .. Clutch Release Arm Shaft Spring / 1948/52 trucks / Obsolete
CARPENTER NOS OBSOLETE PARTS has 4,304.
Pic: 1952 Ford Trucks, 1951 is similar:
zf5 question otpracer 1987 - 1996 F150 & Larger F-Series Trucks 5 09-22-2015 02:42 PM
F100 with a 428 FE- clutch replacement suggestions? PRUSue 1973 - 1979 F-100 & Larger F-Series Trucks 0 04-07-2015 03:43 PM
Need 391 Flywheel, clutch & housing Detail4spd Clutch, Transmission, Differential, Axle & Transfer Case 0 02-17-2015 10:30 AM
Help Finding Clutch Linkage Parts Macs1964F100 1961 - 1966 F-100 & Larger F-Series Trucks 4 03-02-2014 10:28 PM
need help finding lowest price on clutch 808 7.3 1999 - 2003 7.3L Power Stroke Diesel 3 04-24-2008 09:59 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
