'85/'82 build thread
#48
I am inclined to agree with you Gary. My ol gal wont outrun some cammed up hot rodded out truck or Bronco, but I would hook bumpers with about any Windsor powered vehicle around. She aint made to go fast, she is made to GO. Its funny how alot of people put down the M motor, but there are possibly still millions of them going strong today. When they can "breathe" right they are capable of performing right up there with about any engine made. Just costs alot more to do.
#49
Not to hijack Brad's wonderful thread, I'm just messing with him. The Windsors are one of Ford's all time most popular engines and the M/400's are some of the least popular. But that doesn't mean they aren't good, just misunderstood.
Anyway, back to Bronco's. My son has always wanted one and I'm taking notes on here. Wonderful build!
#50
I've never had an M before but a couple of friends of mine have. Where the torque comes on in the RPM range it's almost like a diesel! And pull all day too. I'll have to try one someday, but I sure like the way a Windsor will rev with a bit of work btw, when I built my 408W I found out that 351W and 351M/400s share the exact same main bearings
Gary I know you and your son will have a blast with a Bronco. My Dad and I sure do. When I got the blue '85 I just wanted a bush buggy to really beat on but they're getting so scarce around here that I couldn't just wreck it. Besides, they're just too cool. I'll have some more pics up tonight once I get back to "The Rez." I just hope they fixed their internet....
#51
#52
Made some more progress this weekend! I'll be glad to have these floors finished.
This one was right around the seat bolts on the driver's side. It took a bit of patience to make but I cut out the rotten stuff and it fits like factory!
Then finished the welds and put some self etching primer on it.
Finally time for seam sealer! Once it dries enough I'll sand it and finally paint the floors - at least the front section, still have the spots by the seatbelts to do. Not taking any chances with how much salt gets put on our roads so rustproofing is our main priority, otherwise they might be a little prettier
This is the one spot behind the seatbelts on the passenger side. The driver's side is the same way. I know what you're thinking, but it's not rotten at all at the anchor points so it's plenty safe enough. Just the tin work next to it.
Once the rot is cut out this patch will fit in perfect.
The one and only rust spot on the passenger side quarter. Anyone that's not familiar with these trucks, as I wasn't before this, they have a tendancy to crack at the top of the cab behind the drip rail when the tops are off. This lets moisture run down the inside of the cab and settle in the factory's inconveniently placed insulation. Then it rots out at the bottom. Plus they gather mud in between the two panels right behind the rocker panels too. Just a spot to look for to anyone looking to buy one!
This is the area here, behind where I have cut out. They're popular for rust. Lucky for me it's still solid, wouldn't have been for long though I don't think. So I cleaned all the rust off, put the rust treatment to it and coated the wee out of it with black underguard. Then put in a new piece of steel.
That's it for this week. Here's what people see when they first see it. Most of them aren't too optimistic, but I can see it!
#54
Thanks Gary it's starting to look pretty good I think. It's already came a long way from where it was when I dragged it home. I have a line up of buddies that already want to go for a tour with the top off!
#56
#57
I mentioned the 306 that I'll be putting In the truck in some other posts. I had it in my Flareside for a few years before I put in the 408. Won't even have 10,00 clicks on it.
It's a '91 roller block from a Mustang GT that Dad and I rebuilt. Its bored .030" over with a set of Keith Black flat top pistons. It's right around 9.7:1 compression, I've never tried it on regular but I have a feeling it'd be okay with it. It's got a Comp XE274 cam, Comp chromoly pushrods and Scorpion 1.6 full roller rockers. The heads are AFRs with 60cc chambers and for up top I've got an Edelbrock Air Gap with a 670 Holley street avenger on it.
It's a pretty snotty little engine which should make for a lot of fun with the 4 speed behind it.
#58
I like it! With the tall valve covers on it is hard to tell it isn't a 351. Good looking engine. In fact, as I think about it that's a bunch like my "stroked M" will look. Yes, it will be bigger, but with a blue block, aluminum heads/intake/waterpump that's a whole lot like mine. Do you mind if I post your pic(s) in my thread? I want to have some dialog about selecting colors?
#59
#60
