6.4 Stuck with Gelled fuel
It's been around 0 to 10 F for the past week or two here. My 2008 6.4 starts fine @0 then drives about 10 miles and quits. This has happened on several different occasions and seems better when the temp gets in the mid-upper teens. I let it sit for about 10 min, it starts up and goes 5-6 miles...quits and repeat and repeat and repeat.. I got to a station and filled up (~12 gallons) and drove fine with temp ~15 F ..... ~ 22 miles ). I have the fuel and oil filters changed RELIGIOUSLY every 5k miles (About 2k miles ago now). I had added double doses of Diesel Kleen Anti-Gel (not 911) at the first occurence. Does the HFCM have a heating element that might not be working? I haven't gotten under the truck to drain the HFCM yet. Any ideas? ford dealr here is backed up 2-3 weeks with diesel issues. Thanks and regards...joe
__________________
It sure was more fun reading about this stuff BEFORE I got my truck than it is writing about this stuff AFTER I got it! (It's still a NICE TRUCK)
2008 Lariat; Black F-350 4x4 6.4; Crewcab; short bed; 3.73 rear; 20" Ford wheels and tires.
__________________
just to make sure, you are running the white bottle of power service Diesel Fuel Supplement(anit-gel), Not the grey bottle of power service Diesel Kleen(non Anti-gel).
so you added the power service after it acted up the first time correct? if so i wonder if the filters are partially plugged up and wont clear itself out without replacement of filters?
i think the fuel cooler would act as a heating unit when the truck is running?
where ya from?
Thanks!
I am sure I used the white bottle of Anti Gel. I specifically read the label for this since I had the problem. I guess I could have gotten a bad tank of fuel, but the problem only started in the cold weather. When I added some warm fuel (from an underground tank at a filling station), it seemed to clear the problem up since the truck got me home and then gave me a problem again after the truck sat over night at below 0.
I do not have a Water warning on the dash...
I thought there would be SOME method to warm the fuel also, It seems strange that I would get that far before the truck quit.
I live in Northern New New Jersey; Mt Olive twp...Flanders/Budd Lake
I appreciate every one's responses. I haven't worked up the courage to lay on the ground (6 in of packed COLD snow!) and open the drain and I have never opened the fuel filter. This doesn't seem like a good time to practice I have resigned myself to getting this thing to the dealer. It's supposed to get above freezing later this week-end
Regards...joe
Regards...joe
If I can monitor this on the CTS, what should it be? It did post a p0097 low fuel pressure code ONE time, but not consistently when I have had problems.
