What rear Springs??? - Page 2 - Ford Truck Enthusiasts Forums
Old 01-25-2014, 12:09 AM
Dano78's Avatar
Dano78 Dano78 is offline
Dano78 has a good reputation on FTE.Dano78 has a good reputation on FTE.Dano78 has a good reputation on FTE.
Quote:
Originally Posted by big schott View Post
I may at some point in the future but, for now I'd like to put money into just getting this thing back on the street.
For the rest..... This has been some GREAT information!!!! Thank You!!
I do have one last question....
I purchased U bolts and the spring perch and accessories for the axel to be bolted on top of the springs... Can I use U bolts and have the nuts pointing UP or do I need to purchase something else?
Im thinking possibly not. Would you be able to post a pic of this hardware? Will be able to tell you if you can at least use the u-bolts or not. You know, an axle flip alone will give you a good 4" drop. Its my understanding that it requires a c-notch but for chits and giggles, id install the axle upside down (above the springs if pads arent removed yet) with that hardware and see what you have.
Old 01-25-2014, 12:11 AM
Dano78's Avatar
Quote:
Originally Posted by avf100 View Post
My rear brackets are good, but I wanted to use all poly bushings (no brass) frt and rear.
So I bought a pair of Posie's superslide springs and the Mid-fiftys frt and rear brackets.
Yep, just knock the brass bushing out of each y-hangar and you're good to go. If the posies springs come with the brass bushings installed, you'll have to knock those out too.
8" Lift f250 SD etdavenport 1999 to 2016 Super Duty 4 06-25-2016 11:58 PM
PROJECT: Front Spring Replacement AWD 93nighthawk Aerostar 12 05-31-2016 08:09 PM
1967 Highboy Lift Springs Super Duty Confused MongooseV8 1967 - 1972 F-100 & Larger F-Series Trucks 1 05-09-2016 11:26 AM
cheap lift ideas. Junkyard parts etc... 96inline 1987 - 1996 F150 & Larger F-Series Trucks 2 02-18-2016 09:42 AM
What's the options? Rear springs 77' 250 RWD CC lostonmonday 1973 - 1979 F-100 & Larger F-Series Trucks 7 06-28-2013 01:59 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
