My 2012 superduty needs a new engine - Ford Truck Enthusiasts Forums
6.2L V8 Discuss the 6.2L V8
Old 01-23-2014, 11:33 AM
GASPIG88 GASPIG88 is online now
GASPIG88 is starting off with a positive reputation.
Unhappy My 2012 superduty needs a new engine
It is with great distaste i report to you fellow Ford truck enthusiasts that my 2012 Ford superduty CC SB FX4 6.2L FLEX Tuxido Black with Black and machine wheels and 35X12.50 Hankcook Dynapro M/T tires
this truck will be recieving a heart transplant now on monday.
Truck developed a ticking sound a 15,300 miles, at 17,850 the call was made by the "engineer" they called down from someplace up north.
i used a stethoscope and i swear to jesus its an injector... its hammering its A$$ off compaired to the other 7... told em.... they kept it 3 days " evaluating" and they say no.
they say its bottom end and they'll have to pull it to inspect and if he's going to pull it he says he would rather put me a new one in, and the ford service manager said they will throw in 5 years on the engine from date on installation 150,000 miles and as long as i own it free services.... but if its possibly something small why not try replacing the ingector first before ripping the engine out and scattering it about the shop.....
still driving it, no codes thrown no dummy lights. no loss in fuel economy or performance. just a ticking that escalates in frequency with in relation to engine RPM, no relative change in the noise due to load.
WTF do i do??? let em put me a new one in? im having 6.0 powerstroke flashbacks... is this a common issues in 6.2L superduty trucks?
in my experience a truck is never the same after n engine swap... its a major undertaking and its invasive post assembly line, ive done quite a few on older trucks... have things changed with newer tech?
i researched before i bought and found NO problem reports.
if im in the wrong place somebody point this smoke wagon in the right direction!
Old 01-23-2014, 06:05 PM
Lakelover's Avatar
Lakelover Lakelover is offline
Lakelover is starting off with a positive reputation.
Engine noise can be hard to nail down, I was trained in mechanics and worked at a dealership and other garages over the years I have built performance engines and the standard rebuilds / service, if they think its the crank/wrist pin then I would trust them, personally I would rather have the new engine vs them taking it apart and putting it back together, and it sounds like they are going to take care of you for the problem.
I would be upset as you are, however it sounds like they are treating you right and in the end all will be good!
Old 01-23-2014, 06:22 PM
jeepnford jeepnford is offline
jeepnford is starting off with a positive reputation.
If it's the bottom end I would rather have a new engine in place of a 17k mile one that's had major repairs. What will it take them, a couple of days? If it's a complete new engine with a good mechanic I think all will turn out good.
Old 01-23-2014, 07:01 PM
T diesel T diesel is online now
T diesel has a good reputation on FTE.T diesel has a good reputation on FTE.
A blessing in disguise.
Old 01-23-2014, 08:34 PM
claycomotrucks1991's Avatar
claycomotrucks1991 claycomotrucks1991 is offline
claycomotrucks1991 is starting off with a positive reputation.
Go with new engine
Old 01-23-2014, 08:50 PM
saratoga2011's Avatar
saratoga2011 saratoga2011 is offline
saratoga2011 is starting off with a positive reputation.
If you suspect one bad injector and they're dead set on replacing the whole shebang, pull the rails and move the suspect injector to the other side. Reassemble and start... see if the noise follows the injector.
You can do that yourself without too much trouble and it sounds like you don't have a lot to lose at this point.
Old 01-23-2014, 11:18 PM
But if I work on it and its noticed it voids warranty? Right?
New fomoco injector is like 40 bucks on rock auto....
I'll put that in if I didn't think i would void the warranty
Old 01-23-2014, 11:21 PM
Its not that I DON'T want that shiny new engine
But why? If I'm right......
Old 01-24-2014, 07:27 AM
JohnnyThunder JohnnyThunder is offline
JohnnyThunder is starting off with a positive reputation.
Right or wrong in your diagnosis. Your dealer wants to give you a new engine and an amazing warranty. I am sorry but how could anyone be upset about that regardless of the miles on your truck. All it takes is a search on this forum and by google to see there are very very few issues with the 6.2l engine and it has been around since 2010. So you may have a bad one, that sux but be happy you are being looked after in the manner Ford has chosen to. I would be grinning from ear to ear in that situation.
Old 01-24-2014, 08:32 AM
96sherm's Avatar
96sherm 96sherm is offline
96sherm has a spectacular reputation.96sherm has a spectacular reputation.96sherm has a spectacular reputation.96sherm has a spectacular reputation.96sherm has a spectacular reputation.96sherm has a spectacular reputation.96sherm has a spectacular reputation.96sherm has a spectacular reputation.96sherm has a spectacular reputation.96sherm has a spectacular reputation.96sherm has a spectacular reputation.
No one wants to have troubles and possible down time, but be thankful your dealer didn't look at your tires and say that they're causing the problem because they're oversized and not OEM equipment My 2012 6.2L had a tick also. Didn't matter if it were warm or cold, hear it real bad when stopped beside a building. I made the issue go away.
In your shoes I'd be thankful they're replacing the engine.
Old 01-24-2014, 08:33 AM
Slowpoke Slim's Avatar
Slowpoke Slim Slowpoke Slim is online now
Slowpoke Slim has a very good reputation on FTE.Slowpoke Slim has a very good reputation on FTE.Slowpoke Slim has a very good reputation on FTE.
+1
As I said in the other thread you started about this...
I really don't get this at all. They want to go above and beyond and give you a new engine...
And you're unhappy about it?
Old 01-24-2014, 01:05 PM
Because an engine swap is invasive.... and if I can get away with a tiny repair why not?
But I already too them I will take the new engine and warranty, set an appointment for the estimated date the engine is to arrive.
Rental will be a f150 ecoboost says the service manager.
Gulf Coast Ford in Angleton TX is an outstanding dealership with knowledgeable service men and women.
Old 01-24-2014, 05:10 PM
LCT LCT is offline
LCT is starting off with a positive reputation.
Geez, that is one heck of a dealer. This is a no brainer in my opinion. Enjoy your new engine and better luck to you. Kind of disheartening though to hear about your engine failure.
Old 01-24-2014, 10:41 PM
Flatbed Ed's Avatar
Flatbed Ed Flatbed Ed is offline
Flatbed Ed is starting off with a positive reputation.
If all it's doing is making a ticking sound, in all likelihood the injector(s), I don't see why you would need a new motor.
My 6.2 has 104,000 miles and ticks at start up but has no other issues at this time. Ford must want a 6.2 from a customer to tear down to examine real world wear and tear??? I don't know.
Ford should take my motor and give me a new one, after all I have 104,000 miles.
Ford............are you listening ?????
Old 01-25-2014, 12:21 PM
Haha I know right? I just wanted the ticking to stop because its annoying nd its my new truck! next thing I hear is hey cant figure it out we're prepared to order a new engine....I agreed to it immediately but had second guesses...
However after hearing these posts haha it didnt take long for me to throw my hands back and lettem git after it.
Think im going to put some exhaust on it after this next break In period
2012 6.2L annoyance biz4two 6.2L V8 36 03-17-2016 12:33 AM
Typewriter Noise or Not? jh225 6.7L Power Stroke Diesel 21 09-21-2015 10:30 PM
"typewriter" noise showed up at 36k djjoshuad 6.7L Power Stroke Diesel 25 01-25-2015 12:30 AM
Engine tick to blown motor? bdorin 2007 - 2014 Expedition & Navigator 17 03-22-2013 09:16 AM
Real world testing of the FORD 6.2 Liter gas engine Superduty ggadwa 1999 to 2016 Super Duty 4 09-30-2012 01:12 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
