Misfire scanner
Misfire scanner
What kind of scanner do I need to be able to single out the cylinder causing the misfire. I have access to a code reader but I have looked through the booklet and even the settings on the tool and I see no way of reading the codes while the truck is running. It will only read codes with engine off ignition on. Can someone tell me what I need. Thanks! 2002 f250 5.4
An Android smart phone, a $20 BT/OBDII adapter and a $5 app is usually adequate.
See this thread: https://www.ford-trucks.com/forums/1...bd1-obdll.html
mcastleberg
08-13-2003 11:11 AM
