Ford Expedition 2003 - softer shock absorbers - Ford Truck Enthusiasts Forums
1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Old 01-23-2014, 03:08 AM
Norexp Norexp is offline
Norexp is starting off with a positive reputation.
I have a Ford Expedition 2003 model, with coil springs.
I changed OE shocks for Bilsteins for some years ago. Truck handles really well, but it is a little to firm for my liking. I would like a soft handling, almost like riding on a cloud. I am not worried about the truck handling as a sailboat, as I almost never do any high speed driving.
Does anyone have experience to share with soft dampers? I don`t know if there is oildampers for second gen. Expedition, but I wuld thing that would be more comfortable for my type of driving.
Thank you for any help.
Old 01-23-2014, 03:15 AM
alloro alloro is online now
alloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to behold
Switch to Monroe Gas shocks. You'll still get good control but it won't be so stiff of a ride.
Old 01-23-2014, 03:37 AM
Thank you.
Any Monroes which are prefered, or perhaps there is just one type which fit Expeditions?
I really would like this "ride on a carpet" feeling.
I have a friend with a Tahoe 2003, and it has a much softer and comfortable ride.
Tires are one year old Coopers in OE dimension, and pressure is also OE.
The Bilsteins are very good quality, and handles really well on roads which isn`t straight, but I could feel dumps a little to much. Even the letters and roadmarkings is felt, hehe.
Old 01-23-2014, 09:16 AM
jdecker jdecker is offline
jdecker is starting off with a positive reputation.
I'm not sure you'll notice the difference your looking for by simply changing shocks. I think the spring rate would dictate more what your looking for and as far as I know (maybe some one does?) there aren't any softer after market springs. You can try a softer side wall tire and it will help some. I recently switched from continental lx20 to michelin and there was a very noticeable difference, but it's still pretty rough.
Old 01-23-2014, 09:29 AM
Thank you.
I have thought about spring rates. Ford in the USA wont tell me if there is different spring rates for my year. They keep telling me dealership in Norway should provide me this information. Problem is that there is only a few US trucks in Norway, and dealership cant give me any information.
I have searched for aftermarket springs with lower springrate, but cant find any.
As for tires, I cant change to P tires. Norwegian laws tell me I need LT tires.
Old 01-23-2014, 07:38 PM
lv2race's Avatar
lv2race lv2race is offline
lv2race is gaining momentum as a positive member of FTE.lv2race is gaining momentum as a positive member of FTE.
Last year, I bought a set of Gabriels and it seemed like we felt every pebble and crack in the road. Took those out and replaced them with a set of Monroe's and the ride is MUCH smoother.
Go with the Monroe's!
Old 01-24-2014, 03:49 AM
Thank you.
Seems like Monroes is the way to go.
I see that Summit has shocks and coils as a package. I wonder if the coils has the same springrate as OE? Perhaps the easiest way to choose is to buy these, since I then dont need to compress coils.
Will need to do same math, since shipping and tax to Norway is expensive.
Thanks for any experiencesharing.
Old 01-25-2014, 09:20 AM
cbrown9064 cbrown9064 is offline
cbrown9064 is gaining momentum as a positive member of FTE.
I don't know if you will see much difference by switching shocks. I have noticed a significantly better ride by dropping the air pressure in the tires to around 30. Two problems with that is a bit more abnormal tire wear, and the tire pressure warning light will come on in colder temps.
The tires are most of your ride quality issues. The LT tire will be a stiffer ride. When we put 10 plys on the F250, we could notice a significant ride quality difference (rougher) than the 8 plys...
Old 01-25-2014, 10:36 AM
Quote:
That is just flat out bad and dangerous advice. Running your tires low reduces traction and braking ability because the tires are not flat across where they touch the road. It also decreases MPG, and cause the tires to run hotter. Low tire pressure also causes excessive flexing of the tire and leads to early breakdown and cracking of the rubber material.
Low tire pressure also causes more traffic accidents.
Study finds low tire pressure a factor in many crashes | Fox News
Old 01-25-2014, 10:37 AM
5.4T's Avatar
5.4T 5.4T is offline
5.4T has a very good reputation on FTE.5.4T has a very good reputation on FTE.5.4T has a very good reputation on FTE.
thank you !! my truck feels like this! now I know why!!!!
Best replacement shock???? big red power 2004 - 2008 F150 13 09-15-2016 11:30 PM
Replacing shocks FordYoungGun35 1987 - 1996 F150 & Larger F-Series Trucks 13 11-17-2013 05:06 AM
1998 ford expedition door handle conversion cleaningbug94 1997-2006 Expedition & Navigator 4 10-19-2010 07:40 PM
Large SUV Ride and Drive polarbear Ford vs The Competition 16 02-27-2006 10:53 PM
Special Edition Supercharged Harley Expedition..... hackatak 1997-2006 Expedition & Navigator 3 01-15-2003 07:04 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
