Bucking Truck - Ford Truck Enthusiasts Forums
Bucking Truck
Old 01-23-2014, 01:48 AM
tchristian tchristian is offline
tchristian is starting off with a positive reputation.
Bucking Truck
I'll apologize in advance if this has been addressed in posts elsewhere, but I'd like to get a few opinions.
I have a 1958 F100 with a 292 y-block, 2v, 4-speed manual. The other day while driving on the freeway it began bucking violently. I thought it was starving for gas, so I replaced fuel filters, air filter, and even the fuel pump (which had previously been replaced with an electric). None of this seemed to help. I replaced spark plugs and HT leads about 500 miles ago, so I'm assuming they're OK. It seems to start bucking at about 45-50 mph going uphill. Is a carb rebuild the next step, or is there something else that might fix it? New coil maybe? Any suggestions would be appreciated. Thanks.
Old 01-23-2014, 01:52 AM
FortyNiner's Avatar
FortyNiner FortyNiner is offline
FortyNiner is a splendid one to beholdFortyNiner is a splendid one to beholdFortyNiner is a splendid one to beholdFortyNiner is a splendid one to beholdFortyNiner is a splendid one to beholdFortyNiner is a splendid one to beholdFortyNiner is a splendid one to behold
When you replaced the filter, was it clogged?
Old 01-23-2014, 02:13 AM
The Horvaths The Horvaths is offline
The Horvaths has a good reputation on FTE.The Horvaths has a good reputation on FTE.The Horvaths has a good reputation on FTE.
I have seen a damaged clutch/pressure plate cause bucking under load. However, I'd check float level or even rebuild carb before suspecting that.
Might try a fuel flow test. That would let you know if the fuel line is clogged, has a pinhole leak, or the tank's sock is clogged.
Old 01-23-2014, 06:57 AM
f5fordgirl f5fordgirl is offline
f5fordgirl is starting off with a positive reputation.
Might check the point gap too.
Old 01-23-2014, 07:31 AM
bigwin56f100's Avatar
bigwin56f100 bigwin56f100 is online now
bigwin56f100 has much to be proud ofbigwin56f100 has much to be proud ofbigwin56f100 has much to be proud ofbigwin56f100 has much to be proud ofbigwin56f100 has much to be proud ofbigwin56f100 has much to be proud ofbigwin56f100 has much to be proud ofbigwin56f100 has much to be proud ofbigwin56f100 has much to be proud of
Sounds like an ignition misfire to me
Old 01-23-2014, 07:59 AM
Branded's Avatar
Branded Branded is offline
Branded has a good reputation on FTE.Branded has a good reputation on FTE.
Vacuum leak ??
Old 01-23-2014, 11:13 AM
Quote:
No, the filter was actually pretty clean.
Old 01-23-2014, 11:14 AM
Quote:
I changed out the points when I did the plugs a few months ago. I can check the gap, but I don't think that's moved since then.
Old 01-23-2014, 11:21 AM
It's funny you mention the clutch. That's something that's been in the back of my mind, as there's been some slippage under load/acceleration. I've also been noticing the "burnt brake" smell lately. I'm inclined to follow that lead before rebuilding the carb since it obviously needs the clutch regardless. I just wasn't sure if that's something that would have caused bucking rather than loss of power altogether. Why would a worn clutch cause that? Would it be the clutch plate slipping then suddenly grabbing the flywheel?
I'll also check the tank sock. The sending unit is in need of replacement anyway, since I'm getting inaccurate fuel level readings (full tank registering as only a quarter).
Old 01-23-2014, 11:52 AM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is online now
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
Fuel usually isn't a cause for bucking, it's usually ignition. Check the wire that goes from the coil to the points. Where it runs under the points plate, they can get chafed and short out intermittently when vacuum advance moves the plate.
Old 01-23-2014, 12:59 PM
arctic y block's Avatar
arctic y block arctic y block is online now
arctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputation
X2 on what Ross said^^^^^^ . This is your problem I would bet for sure.
Or in that area. I have seen this so many times and it will drive ya nuts.
Old 01-23-2014, 01:49 PM
dadgonebroke dadgonebroke is offline
dadgonebroke is starting off with a positive reputation.
bucking
Quote:
I admit this doesn't happen often but I had a car that was only driven for a one week period each year. When I was done driving each time- I would fill the gas tank to the top. After a few years, it drove just fine from full tank down to half. If I let it get under 1/2 it would buck like a bronco! The tank was pulled and had more than 5 gallons of water in it.
Old 01-23-2014, 02:50 PM
Arctic, which one is Ross?
Old 01-23-2014, 02:54 PM
Broke dad, I took a look in the tank this morning and it doesn't appear that there's any water in it, unless it's homogenized with the gas really well
Old 01-23-2014, 03:29 PM
FortyNiner's Avatar
Quote:
Ross is ALBUQ F-1
E4OD in a bad mood? F350 Diesel Bucking and Surging SuperABen 1987 - 1996 F150 & Larger F-Series Trucks 5 08-02-2015 03:52 PM
Fuel filter montey2005 6.7L Power Stroke Diesel 10 06-23-2015 08:23 PM
Issues on 2001 Ford F250 - Slight bucking under load MudFlappin 1999 to 2016 Super Duty 15 05-13-2015 03:10 PM
Dying in reverse and bucking, both intermittent... JoeNoble 1987 - 1996 F150 & Larger F-Series Trucks 3 06-09-2014 01:51 PM
I need help with my 1990 F150 ext cab please-updated again new codes help please:) court1100f 1987 - 1996 F150 & Larger F-Series Trucks 30 01-29-2011 12:20 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
