Bucking Truck - Page 2 - Ford Truck Enthusiasts Forums
Bucking Truck
Old 01-23-2014, 06:58 PM
tchristian tchristian is offline
tchristian is starting off with a positive reputation.
Quote:
Originally Posted by ALBUQ F-1 View Post
Fuel usually isn't a cause for bucking, it's usually ignition. Check the wire that goes from the coil to the points. Where it runs under the points plate, they can get chafed and short out intermittently when vacuum advance moves the plate.
Problem solved (at least it appears to be)! Thanks to everyone for their input, especially Ross. I looked at the wire from the points to the coil, which although not chafed was loose to the point where I could pull it away from the points with my fingers. It had contact, but I'm guessing when the vacuum advanced the timing it would move the points away from the wire breaking the connection and then reconnect when timing retarded. I wouldn't have looked there without all of your input.
I need to get a more reliable mechanic...
Old 01-23-2014, 07:22 PM
FortyNiner's Avatar
FortyNiner FortyNiner is offline
FortyNiner is a splendid one to beholdFortyNiner is a splendid one to beholdFortyNiner is a splendid one to beholdFortyNiner is a splendid one to beholdFortyNiner is a splendid one to beholdFortyNiner is a splendid one to beholdFortyNiner is a splendid one to behold
Rep points are in order - use the heart icon on the upper right of Ross' post to recognize his contribution.
DW
Old 01-23-2014, 07:43 PM
Quote:
DW
Done. Thanks!
Old 01-24-2014, 03:22 PM
arctic y block's Avatar
arctic y block arctic y block is offline
arctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputation
Glad ya got it fixed for now Bud.
E4OD in a bad mood? F350 Diesel Bucking and Surging SuperABen 1987 - 1996 F150 & Larger F-Series Trucks 5 08-02-2015 04:52 PM
Fuel filter montey2005 6.7L Power Stroke Diesel 10 06-23-2015 09:23 PM
Issues on 2001 Ford F250 - Slight bucking under load MudFlappin 1999 to 2016 Super Duty 15 05-13-2015 04:10 PM
Dying in reverse and bucking, both intermittent... JoeNoble 1987 - 1996 F150 & Larger F-Series Trucks 3 06-09-2014 02:51 PM
I need help with my 1990 F150 ext cab please-updated again new codes help please:) court1100f 1987 - 1996 F150 & Larger F-Series Trucks 30 01-29-2011 01:20 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
