Need help with REAR end selection!!!! - Ford Truck Enthusiasts Forums
Old 01-22-2014, 08:23 PM
Mitch01675's Avatar
Mitch01675 Mitch01675 is offline
Mitch01675 is starting off with a positive reputation.
Here is what I am running. I am installing a 302/340 horse crate motor running a C4 transmission that I already have. I was wanting to install a Ford 8.8 out of an explorer with the disc breaks and locker. So my question remains is what size gears would I need to have in the rear end to be the best. I was thinking of 373 locker. Any suggestions. Thanks for all the knowledge.
Mitchell
Old 01-22-2014, 09:07 PM
das54's Avatar
das54 das54 is offline
das54 has a very good reputation on FTE.das54 has a very good reputation on FTE.das54 has a very good reputation on FTE.
what size tires. I have 235-75R15 that are about 29" dia., a 2.91 rear and 4 speed AT. At 70 mph the engine is turning 2360 rpm in 3rd, 1652 in 4th. A little low but probably ok with a torquey engine and not pulling a load. A 3.73 rear would be running 3026 in 3rd and 2118 in 4th. A 3.50 about halfway between these 2. I might pull my camper trailer with mine so I might go looking for 3.50 - 3.73 gears some day.
Old 01-22-2014, 09:58 PM
Mitch01675's Avatar
Front Tires are going to be 255/40/18 and the rear tires are going to be 285/30/20. I am believing the 373 gears should be fine. Not doing any real hauling with the truck or towing a camper. Just a weekend rod and maybe a beach trip or two. Thanks
Old 01-22-2014, 11:32 PM
das54's Avatar
26.7 in diameter tires with 3.73 rear and C4 tranny you'll be turning 3287 rpm at 70 mph. Seems a bit high. I've read that the Explorers also had 3.27 and 3.55 trac-loc rears but seems the 3.73 is most common. Your's will be pretty quick off the line with a 3.73 and those wide meats out back. Good luck with your build.
Old 01-23-2014, 08:41 AM
56panelford's Avatar
56panelford 56panelford is offline
Posting Legend
56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation
Tight and firm is the way I like em!
Old 01-23-2014, 10:57 AM
Wayne Waldrep's Avatar
Wayne Waldrep Wayne Waldrep is offline
Wayne Waldrep has a very good reputation on FTE.Wayne Waldrep has a very good reputation on FTE.Wayne Waldrep has a very good reputation on FTE.Wayne Waldrep has a very good reputation on FTE.
I was considering an explorer 8.8 in mine. My local wrecking yard had about 20 explorers. The majority of them were 3.55 drum rear ends. All the others were 3.73 with either drum or disc. The tag will show 3L73 if it is traction lock and just 373 if its open. My personal preference with a C4 would be the 3.55. That engine has more than enough torque to handle a more highway friendly gear. Of course I'm not a C4 fan really....I like the AOD.
Old 01-23-2014, 11:09 AM
Mitch01675's Avatar
Just picked up a 8.8 with 327 with locker and disc brakes for $300 and they are pulling it out for me. Be ready in the morning. We live in a small town and really won't be on highway with the truck to often.
Old 01-23-2014, 01:42 PM
Quote:
Congrats!! That's perfect in my book.
Old 01-23-2014, 08:08 PM
Mitch01675's Avatar
Alright guys without me starting a new thread seeing if yall might have any advice. With the new 8.8 rear end I am planning on installing 20x10 in the rear and 18x8 in the front. Do I Have to install widened rear fenders or do you think I would be able to retain stock rear fenders. These are smooth steel wheels.
Thanks
Old 01-23-2014, 08:58 PM
Posting Legend
Do you have more than 12 inches between the box and fender lip, backspacing and ride hieght? There was only 6 '' rims originally
Old 01-28-2014, 07:42 PM
Mitch01675's Avatar
Well got my 8.8 rear end. Stripped it down, replaced rotors, pads, bearings, and flushed and refilled oil. Painted it black and painted diff cover the color truck will be. I know I have to cut old perches off but just couldn't stop. Good to see it looking nice though.
[IMG]<a href="http://s1371.photobucket.com/user/mitchellbwhite/media/Ole%20Bessie/IMG_7050_zps40b2ae04.jpg.html" target="_blank"><img src="http://i1371.photobucket.com/albums/ag288/mitchellbwhite/Ole%20Bessie/IMG_7050_zps40b2ae04.jpg" border="0" alt=" photo IMG_7050_zps40b2ae04.jpg"/></a>[/IMG]
[IMG]<a href="http://s1371.photobucket.com/user/mitchellbwhite/media/Ole%20Bessie/IMG_7051_zpsc1510941.jpg.html" target="_blank"><img src="http://i1371.photobucket.com/albums/ag288/mitchellbwhite/Ole%20Bessie/IMG_7051_zpsc1510941.jpg" border="0" alt=" photo IMG_7051_zpsc1510941.jpg"/></a>[/IMG]
[IMG]<a href="http://s1371.photobucket.com/user/mitchellbwhite/media/Ole%20Bessie/IMG_7052_zps98b5a139.jpg.html" target="_blank"><img src="http://i1371.photobucket.com/albums/ag288/mitchellbwhite/Ole%20Bessie/IMG_7052_zps98b5a139.jpg" border="0" alt=" photo IMG_7052_zps98b5a139.jpg"/></a>[/IMG]
Old 01-28-2014, 07:53 PM
avf100's Avatar
avf100 avf100 is offline
avf100 has a great reputation on FTE.avf100 has a great reputation on FTE.avf100 has a great reputation on FTE.avf100 has a great reputation on FTE.avf100 has a great reputation on FTE.
Thanks
I think 10 " will be to wide if the truck is lowered. I have 17X8 with 235/55-17 tires and have about 1/2 " clearance on each side of the tire. (bedside & fender side)
Old 01-28-2014, 08:09 PM
Mitch01675's Avatar
I have conceded to getting a set of 20x8 steel smoothies from Detroit Wheel Company. Gonna have them powder coated to match truck.
Aussie Locker: First Impression natewoz Offroad & 4x4 7 12-30-2015 08:05 AM
Locker for 2wd trailrider121 1987 - 1996 F150 & Larger F-Series Trucks 51 02-20-2012 04:22 PM
locker, diffs question abriel68 1999 to 2016 Super Duty 21 02-02-2010 10:16 AM
Benefits of a "Locker" rear end? GeneStoner Clutch, Transmission, Differential, Axle & Transfer Case 10 01-20-2005 11:21 PM
03 3.55 rear & air lockers lordthirteen Offroad & 4x4 13 02-19-2003 09:54 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
