429cj in 56 F100 - Ford Truck Enthusiasts Forums
429cj in 56 F100
Old 01-22-2014, 07:52 PM
little56ford little56ford is offline
little56ford is starting off with a positive reputation.
429cj in 56 F100
Does anyone here have an F100 with a big block in it. I need advice on radiator supplier that builds one to fit the stock front end and cool a big block.
Thanks!
Old 01-22-2014, 09:21 PM
B/B ford's Avatar
B/B ford B/B ford is offline
Clean & Classy
B/B ford has a good reputation on FTE.B/B ford has a good reputation on FTE.
I've got a 460 in mine. I used the 4-row one, from mid-fifty (copper-brass)that claims it will cool up to a 460 with A/C in it.
I run it with a radiator shroud and flex fan and I haven't had any issues with it overheating here in the desert of SoCal. This includes running the A/C.
Old 01-22-2014, 09:58 PM
ldouble619 ldouble619 is offline
ldouble619 is starting off with a positive reputation.
I have a 68' 429 in my truck. I order a aluminum 3 row off fleabay, I'll be installing it this weekend.
Old 01-23-2014, 01:06 AM
smallello's Avatar
smallello smallello is offline
smallello has a great reputation on FTE.smallello has a great reputation on FTE.smallello has a great reputation on FTE.smallello has a great reputation on FTE.
I have a 1970 429 in mine with an aluminum 3 row, runs cool no problem.
Old 01-23-2014, 01:05 PM
Quote:
Where did you get you radiator?
Old 01-23-2014, 02:17 PM
ungerp's Avatar
ungerp ungerp is offline
ungerp is starting off with a positive reputation.
While I don't have a 56, I have a 71 429 in my 55. I am running a 3 row aluminum radiator with a 16" electric fan and a 180 thermostat and have not had any heating problems since install and breakin. It stays at 180 degrees no matter what the outside temp is. I may add that this engine is built pretty healthy with a 291TH Comp roller cam, roller lifters, etc. And cruising speed is about 3000RPM with the tranny and gearset I have in it.
Old 01-23-2014, 07:09 PM
Quote:
Where did you purchase the radiator? Thanks
Old 01-23-2014, 08:31 PM
raerjim's Avatar
raerjim raerjim is offline
raerjim is gaining momentum as a positive member of FTE.
Did you mean 428 CJ?
Old 01-24-2014, 12:23 AM
smallello's Avatar
Quote:
It was already in the truck when I got it.
Old 01-24-2014, 12:08 PM
ungerp's Avatar
I was incorrect. It is a 2 row aluminum and I purchased on Ebay. I bought it from Jam n Motorsports and it is an American radiator. AE53-56. It was 184.95 when I bought it.
56 Ford F-100 Big Back Window Conversion Outlaw56 1948 - 1956 F1, F100 & Larger F-Series Trucks 30 11-11-2016 10:59 AM
56 F-100 with AOD Outlaw56 1948 - 1956 F1, F100 & Larger F-Series Trucks 12 09-28-2016 03:14 AM
Convert a f100 back to y block sdhagerman 1948 - 1956 F1, F100 & Larger F-Series Trucks 16 08-14-2014 02:28 PM
500 CID Lincoln Y-block for '53-'56 F100 gary534 Y-Block V8 (239, 272, 292, 312, 317, 341, 368) 18 04-26-2014 08:38 PM
1953-56 Ford F-100 Truck Build, What Transmission, Auto or Manual? ZakBradshaw 1948 - 1956 F1, F100 & Larger F-Series Trucks 11 06-01-2011 06:58 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
