390 distributor ? - Ford Truck Enthusiasts Forums
390 distributor ?
Old 01-22-2014, 07:25 PM
jlb51 jlb51 is offline
jlb51 is starting off with a positive reputation.
390 distributor ?
I just found this distributor in a box marked y-block parts, clearly not the same as my y-block distributor. The # are D8TE 12131--AA. Any ideas? I was looking for a core to turn for a Condone Y-block diss. Thanks Jeff.
Old 01-22-2014, 08:24 PM
MIKES 68 F100's Avatar
MIKES 68 F100 MIKES 68 F100 is offline
MIKES 68 F100 has a good reputation on FTE.MIKES 68 F100 has a good reputation on FTE.MIKES 68 F100 has a good reputation on FTE.
auto parts probably won't notice difference , just pick up rebuilt and pay deposit then return for deposit another day , that way they can't compare side by side
Old 01-22-2014, 11:14 PM
That's a good idea. I'll pick it up Friday, turn the core in sometime next week. Y stuff is sometimes hard ti come by. I've had fe's in the past, didn't know if this was of some value to someone. Thanks Jeff. By the way, my neighbors on my right have a place not to far from you, Johnson Valley. I'm in the Long Beach area. The world IS sometimes small. Thanks again.
anti freeze by the distributor Raptor10 1961 - 1966 F-100 & Larger F-Series Trucks 2 11-01-2016 08:40 AM
Y-Block Question Cobwebman 1948 - 1956 F1, F100 & Larger F-Series Trucks 11 06-12-2016 01:36 AM
Mallory Distributor salf100 1961 - 1966 F-100 & Larger F-Series Trucks 0 07-17-2010 08:08 PM
352 Y-Block??? gangstakr 1961 - 1966 F-100 & Larger F-Series Trucks 11 05-13-2008 10:36 AM
Little Help Identifing this Y-Block Bessie Y-Block V8 (239, 272, 292, 312, 317, 341, 368) 8 12-09-2005 12:35 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
