7.3 modifications
7.3 modifications
I am planning on puuting the 4" exhaust, bigg boost, wiked wheel on turbo, banks waste gate, SCT tuner, and i already have the huge donaldson filter. After that i should be putting out about 580 ft lbs of tourque, will that be too much on the drive train or will i have to upgrade transmissions ? Its a 2002 7.3 with 183,000 miles on it f250
https://www.ford-trucks.com/forums/1...o-results.html
See post #8 which represents what is considered a mildly modified engine. That is about the max you can expect out of stock injectors...
The 4R100 is rated for 1000 ft/lbs of torque so ANY increase in engine output is going to exceed that number due to torque converter multiplication factor.
cherrybomb37
1999 to 2016 Super Duty
12-12-2013 03:35 AM
Stewart_H
24
08-03-2009 09:25 PM
