6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Service engine soon light on,low boost ??
Old 01-14-2014, 07:26 PM
Dadof4's Avatar
Dadof4
Dadof4 is offline
Got in my 08' f350 75,9xx miles on it ,started it up and there it was the little engine icon lit up.started up fine,idles fine,got on the road then noticed it won't make more than 10# of boost no matter how much i push on the pedal.got in the truck again later on same thing but then i get the "drive to clean message" so i drove 25 miles or so and message still there.anybody have any ideas? Could they all be linked together somehow? Gonna get code tomorrow. Only have 1500 miles since last oil n fuel filter changes.drained the water seperator yesterday just like every month. Thanks
Old 01-14-2014, 10:50 PM
RM2738's Avatar
RM2738
RM2738 is offline
DTC's will be helpful...
Is the message "Drive until Clean" appearing or "Cleaning Exhaust Filter?" Is it staying on the cluster the entire time or are you using the System Check feature?
Old 01-15-2014, 05:52 AM
Dadof4's Avatar
Dadof4
Dadof4 is offline
. Yes its the " drive until clean" message stays up the whole time if i push a button it tells me push reset to clear but comes back on and stays
Old 01-15-2014, 09:26 AM
senix's Avatar
senix
senix is online now
Received 1,416 Likes on 1,011 Posts
drive to clean will stay on till it has finally come down some on soot levels. Sometimes if pulling a load it would take longer to go away since you are producing as much as you are burning.
Once enough has burned off it should turn to cleaning exhaust filter, that will stay on till complete in this case.
Much different then the normal routine regen.
Old 01-15-2014, 03:53 PM
golfmedik's Avatar
golfmedik
golfmedik is offline
My bet is one of 3 sensors that monitor the turbo is bad. Had it happen twice now to 2 different 6.4s. Neither would boost, but could rev to redline(if you wanted to) in park.
Old 01-15-2014, 04:00 PM
Dadof4's Avatar
Dadof4
Dadof4 is offline
It's goin in to dealer friday as its still under warranty. So will update the situation then.didnt have time to get codes checked today but on my to do list tomorrow.thats kind of what i was thinking some kind of sensor. Thanks for the input always appreciated
Old 01-15-2014, 04:52 PM
Dadof4's Avatar
Dadof4
Dadof4 is offline
Just got code read came up p1335. Ecm has detected a minimum egr position above a calibrated level. Says probable cause short circuit condition or faulty egr valve. I wouldn't doubt a short circuit with my luck because truck went into shop a month ago about alternator problem and it turned out to be chaffed wiring right near plug on alternator.
Old 01-15-2014, 05:31 PM
Dadof4's Avatar
Dadof4
Dadof4 is offline
I guess i should take it for a long highway run to burn it off.just worried about driving with other p1335 thing going on dont want to wreck anything else
Old 01-15-2014, 05:51 PM
senix's Avatar
senix
senix is online now
two separate issues I think.
Old 01-15-2014, 07:05 PM
GSchretter's Avatar
GSchretter
GSchretter is offline
Oops, you got it covered
Old 01-15-2014, 08:05 PM
Dadof4's Avatar
Dadof4
Dadof4 is offline
Ok so took it 55 miles on the highway doin 65mph to clean exhuast and all i got was the wrench symbol thrown in the mix.message board now is flashing between drive to clean and wrench symbol.could all 3 (no boost,drive to clean and wrench) be intertwined some how ?
Old 01-15-2014, 08:15 PM
senix's Avatar
senix
senix is online now
yes...if you have an egr issue I can see where it is throwing a bunch of exhaust gases. So when you take it in be sure to tell them what you did in an attempt to ensure it was not your driving habits...save them from doing a manual regen till the other issues are looked at.
Wrench light and check engine light issue.
Old 01-15-2014, 09:02 PM
Dadof4's Avatar
Dadof4
Dadof4 is offline
Will do.thanks for the input
Old 01-17-2014, 12:17 PM
Dadof4's Avatar
Dadof4
Dadof4 is offline
Service garage says needs new egr and housing.they have to order it so be a day or so till i get it back.$100 deductible gonna cost me and got free matchbox car rental so not so bad.will see how truck is when i get it back.
Old 01-19-2014, 04:19 AM
Raven56's Avatar
Raven56
Raven56 is offline
I had the same issue one day a few years back. Underwarrenty it was a EGR temp sensor. Made the truck go into a limp mod kinda. Check light and low boost. Hope you get it back on the road.
Quick Reply: Service engine soon light on,low boost ??
