51 ford f2 rear axle nut - Ford Truck Enthusiasts Forums
Old 01-22-2014, 03:20 PM
redneckfordman1 redneckfordman1 is offline
redneckfordman1 is starting off with a positive reputation.
hey guys been working on my brothers truck a little lately trying to get it moving again. i found the right rear brake lockedup due to a bad seal allowing the grease to contaminate the shoes. anyways im tryin to get it all fixed again but im having troubles finding a socket for the main bearing nut. any help would be appreciated
Old 01-22-2014, 03:36 PM
raytasch's Avatar
raytasch raytasch is online now
Old guy with old toys
raytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant future
Wrenches are available. Shown is the correct KD wrench for the Dana 60, 2 9/16". Measure the nut on your axle. Most good auto parts stores will have the socket. Some stores may even have loaners. I bought mine at NAPA.
Old 01-22-2014, 03:52 PM
ive already tried 2 1/4 and 2 3/8 12 point sockets one was too big other too small
Old 01-22-2014, 04:38 PM
raytasch's Avatar
Don't think a regular socket is going to work. Look at the nuts,
Old 01-22-2014, 04:46 PM
Should still give a fair idea of size tho I'd imagine
Old 01-22-2014, 04:48 PM
jmadsen's Avatar
jmadsen jmadsen is offline
jmadsen is a name known to alljmadsen is a name known to alljmadsen is a name known to alljmadsen is a name known to alljmadsen is a name known to alljmadsen is a name known to all
I always just use a hammer and chisel to get it loose! of course I like to do things the hard way...
Old 01-22-2014, 05:02 PM
That's what its lookin like I'm gonna do pretty soon. These are normal threads not reverse correct?
Old 01-22-2014, 05:09 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is online now
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
How are you going to torque it when re-assembling it with a hammer and chisel?!
Old 01-22-2014, 05:12 PM
I won't but if I can at least get it off then illI'll be able to figure out what parts iI need/find correct ones and find a correct socket to put it back together
Old 01-22-2014, 05:19 PM
raytasch's Avatar
Look at the KD part number on the special wrench. Sorry it is upside down. Read the very fine print on the arrows of my picture. This is what happens when the nuts are removed with a hammer and punch.
Edit: disclaimer on the size of the axle nuts on your truck.
Old 01-22-2014, 05:31 PM
ALBUQ F-1's Avatar
postin' fool
'51 F-2 is a different size, 2-3/8" but as Ray says, a regular socket probably won't fit. You need one of the tube wrenches like shown.
Old 01-23-2014, 11:59 AM
arctic y block's Avatar
arctic y block arctic y block is offline
arctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputation
Just go into like Napa and ask for a spindle nut socket. Explain to the
counter kid what it is. Cost is only a few bucks. I also use a chisel and BFH.
most of the time as they are in the tool box and I have to look hard for my spindle
socket.
Old 01-24-2014, 08:07 PM
1952henry's Avatar
1952henry 1952henry is online now
1952henry is gaining momentum as a positive member of FTE.1952henry is gaining momentum as a positive member of FTE.
An original Ford issue (Moore Forging) F3 wheel nut wrench and handle (doubles as tire iron).
92 F150 XLT Rear Shock Question fightlivefree 1987 - 1996 F150 & Larger F-Series Trucks 8 07-02-2016 04:30 PM
89 F250 rear pinion nut problem ... MontanaMan 1987 - 1996 F150 & Larger F-Series Trucks 7 08-05-2015 04:32 PM
Saltwater = Frozen Lug Nuts djed 1999 - 2003 7.3L Power Stroke Diesel 51 06-12-2015 03:29 PM
Flare nut wrenches midlf Garage & Workshop 33 01-26-2005 06:10 AM
Removing NP205 Rear output Flange Lock-nut? GTStang Clutch, Transmission, Differential, Axle & Transfer Case 0 12-14-2004 11:03 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
