96 ford f250 noise in steering wheel.
I have a screeching noise coming from my steering wheel when I turn the wheel. It's coming from where the steering wheel meets the steering column....I was told there is a ribbon in there that could be going bad but ford doesn't know of this part. There is also a burning smell coming from the dash to the left of the steering wheel. Has anyone delt with this issue or know what it is....I prefer to buy parts prior to ripping if all apart.
Thanks
Thanks
My 97 has 392k miles and a shop "shimmed" my steering wheel once a couple years ago.
Recently I was pulling out of a parking lot and my horn started going and off. also the turning wheel was crunching like crazy. I thing the bearings are down below in the column. the photo above may be what was crunching. The horn went off cause i believe
that is a GROUND ring for horn and cruise.
I just got a complete column at the yard, will use parts, or the whole thing depending
on damage. Good Luck !
DeathRangerofDeath
03-01-2015 05:43 PM
